Hi guys, I've owned this little pico projector, the 3M CP45 for 2 years now. I lost the software that came with it: Arcsoft Media Converter 3.1. The company does not support the software or even sell the software anymore. They stopped and offer no support for a patch, download or tech support. I can't convert my movies to a compatible format with Handbrake, AVIDemux, SUPER, or Media Converter 7 and 8. I also tried other programs, but it must be a secret flag in the mp4 to play correctly. Does anybody have this software for the projector or direct experience with it? I saw some discs on ebay, but they were bundled with a new/used one only.
Tom Green Sucks!
This is a working sample. This is a video recorded by the actual camera. Notice it comes up with Sony PSP? I tried Media Converter 7/8 with Sony PSP settings and smallish green macroblocks appeared all over.
General
Complete name : H:\DCIM\100MEDIA\CLIP0002.MP4
Format : MPEG-4
Format profile : Sony PSP
Codec ID : MSNV
File size : 11.4 MiB
Duration : 12s 913ms
Overall bit rate : 7 437 Kbps
Encoded date : UTC 2010-01-01 01:00:03
Tagged date : UTC 2010-01-01 01:00:03
Video
Format : AVC
Format profile : Main@L4
Format settings, CABAC : Yes
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=8
Codec ID : avc1
Bit rate : 7 366 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.267
Stream size : 11.3 MiB (99%)
Language : Japanese
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 12s 907ms
Bit rate mode : Constant
Bit rate : 64.0 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 101 KiB (1%)
Language : Japanese
Tagged date : UTC 2010-01-01 01:00:03Tom Green Sucks! -
Sorry, I seem to be late to this thread. For some reason, I was thinking about the projector this thread showed up on a google search.
Anyway, I ended up finding and editing the original file that defined the formats for Arcsoft Media Converter 3.1 so that it would use the full 720x480 resolution of the projector. It's been a while since I did anything with it so it will take some time to find the right file. I converted a bunch of stuff and it worked great, but I could never get a different program to make a successful conversion.
Here's the mediainfo output for that format:
I attempted to create videos with the following ffmpeg line without success. Any suggestions would be welcome.Code:$ mediainfo bolt.MP4 General Complete name : bolt.MP4 Format : MPEG-4 Format profile : 3GPP Media Release 4 Codec ID : 3gp4 File size : 2.08 GiB Duration : 1h 36mn Overall bit rate : 3 095 Kbps Encoded date : UTC 2013-05-09 14:57:34 Tagged date : UTC 2013-05-09 14:57:34 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 1 frame Format settings, GOP : M=1, N=7 Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 1h 36mn Source duration : 1h 36mn Bit rate : 2 961 Kbps Width : 720 pixels Height : 480 pixels Display aspect ratio : 3:2 Frame rate mode : Variable Frame rate : 30.000 fps Minimum frame rate : 29.973 fps Maximum frame rate : 30.003 fps Standard : NTSC Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.286 Stream size : 1.99 GiB (96%) Source stream size : 1.99 GiB (96%) Language : English Encoded date : UTC 2013-05-09 14:57:34 Tagged date : UTC 2013-05-09 14:57:34 Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 40 Duration : 1h 36mn Bit rate mode : Constant Bit rate : 125 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Compression mode : Lossy Stream size : 86.2 MiB (4%) Language : English Encoded date : UTC 2013-05-09 14:57:46 Tagged date : UTC 2013-05-09 14:57:46
Code:ffmpeg -i coraline.mp4 -acodec aac -ar 48000 -ab 125k -ac 2 -r 30 -vcodec libx264 -vr 2500k -vf "scale=800:-1" -metadata major_brand="3gp4" -metadata minor_version="0" -metadata compatible_brands="3gp4isom" /tmp/junk.mp4
OK, I finally got around to poking at this again. The file is "ArcSoft/MediaConverter 3/Profiles/FormatGen/Local Disk_H264 MP4.xml" in your "Program Files" directory. There's one for all the different formats supported by this software, but the H264 format is going to be most compact. And really the 1280x720 is way beyond the resolution of the projector and just takes up more space for no good reason. You could try 800x533 as well, but 720x480 is pretty standard.
Once you're done with that you have to define a new Video Profile by going to Settings, then the Video tab, then next to "Profile" click "New". The "Video Resolution" pulldown should have the new resolution in it. Give it a name and hit save.Code:[SupportOutPut] Format1=H264 MP4 [H264 MP4] VideoVEncod=ArcSoft H264 Codec VideoResolution=640x480,720x480,1280x720,1920x1080 VideoAspect=4:3,16:9 VideoFPS=30.00 VideoVBitrate=2560,4000,6144,7680 VideoAEncod=ArcSoft AAC Codec VideoASmplrate=48000 VideoAChannel=1,2 VideoABitrate=96,128,160,192 PPTSps=1,2,3,4,5 [Relate] VideoAspect=VideoResolution VideoVBitrate=VideoResolution [Rule] VideoAspect=640x480(4:3)|720x480(16:9)|1280x720(16:9)|1920x1080(16:9) VideoVBitrate=640x480(2560)|720x480(4000)|1280x720(6144)|1920x1080(7680) [RuleEx]
Is there any other software that's compatible with the Elgato HD?
By GEOLINK in forum Capturing and VCRReplies: 24Last Post: 12th Apr 2015, 15:36 -
what is the most compatible video container to convert my files to?
By WuxiIxuw in forum Video ConversionReplies: 51Last Post: 22nd Aug 2012, 20:55 -
AVCHD from panasonic lumix, which software is compatible?
By rocketman778 in forum EditingReplies: 0Last Post: 25th Nov 2011, 16:53 -
M4V Video Not Compatible with Editing Software
By Craig Taylor in forum Authoring (DVD)Replies: 2Last Post: 20th Jun 2011, 12:09 -
compatible files
By woody12 in forum Media Center PC / MediaCentersReplies: 1Last Post: 17th Jan 2011, 12:43
