:o
I have a dvd 710 and it wont play svcds at all, after insertion it spews disk back out. it is region 2 at present, need help on how to beat this problem please??????
Plays vcd fine but not svcd, I have no idea how to find out what version or P that it is playing.
Please help this newbie!
Hey there MCOPTOM,
I have the 710 myself. The good news is, it CAN play SVCD. Actually it plays SVCD by default when the player is set to region1. The trick I used is to make the player region1 first and then make it regionfree so you will be able to play your R2 discs. I have done this about a year and a half ago and I never had any problems. To change regions you will need to enter a code with your remote control, to make it regionfree you will need another code. Because it is NOT without danger of damaging your player or getting it stuck in a region I will not explain or give you the codes here. I suggest you have a look here:
http://regionhacks.datatestlab.com/cgi-bin/forumdisplay.cgi?action=topics&forum=DVD+Re...=20&LastLogin=
and do a search for dvd710. Also have a look here:
http://home.zonnet.nl/jeroenverhaar/
Good luck, Jack (still very happy with his OLD 710) -
Hi Jack
First off thanks for all the help!!
Got another question for you if you dont mind.
I have read the links you told me to but am unsure of how to do the Play code thing
I have One4All 6 control but how do i do the Play code hack
Any help much appreciated
you can reply here or to my email addy#
Cheers
MC
ps IF ANYONE ELSE HAS THOUGHTS PLEASE POST
Philips BDP7500B2 - BD-R DL
By realas in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Feb 2011, 21:34 -
philips DVP3300
By dezxter in forum DVD & Blu-ray PlayersReplies: 3Last Post: 26th Dec 2010, 09:36 -
Philips 3455dvdr stays on philips logo
By vbdanl in forum DVD & Blu-ray RecordersReplies: 7Last Post: 14th Sep 2010, 11:15 -
Can Philips 5990 firmware be used on Philips 5992 Dvd Player
By peggypwr1 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2010, 17:06 -
Philips DVP3960/37
By thebirdf in forum DVD & Blu-ray PlayersReplies: 2Last Post: 19th Feb 2008, 12:34
