What is the best program to edit mp3 files without loss? I have a few files and want to take some pieces from each to create one. mp3directcut looks god but find it hard to use. Is there any one where it is possible to open a blank instance of it and paste in sections
Is goldwave lossy?
EDIT: Found out GoldWave is lossy
You can do that with MP3DirectCut. You can open more than one instance of it, open different MP3s with each, and copy and paste parts of an MP3 from one to the other. That sort of thing......
MP3DirectCut is the only MP3 editor I know of that doesn't require you to re-encode. -
Does mp3 directcut work with the lossless mp3 format mp3HD? http://mp3hd-toolkit.soft32.com/
http://www.pistonsoft.com/mp3-splitter.html ?? Never used this
mp3HD looks like a dead-end that will never gain any traction. Since it's a lossless format you could just decode it to wave for editing, then afterwards encode to mp3HD again without any quality loss, though I'd rather convert to FLAC, AAC or whatever floats your boat.
Scrippt For Ffdshow To Convert Audio To Mp3 ?, I have not installed any MP3
By auto7890 in forum EditingReplies: 3Last Post: 6th Dec 2013, 00:22 -
is any freeware dvd to mp3 or vob to mp3 utility ?
By deejay.2001 in forum Newbie / General discussionsReplies: 15Last Post: 17th Jun 2013, 00:01 -
Remote Editor
By thedoingsful in forum EditingReplies: 6Last Post: 15th Feb 2011, 14:15 -
New to Was Editor
By HoosierGuy in forum EditingReplies: 5Last Post: 23rd Jan 2011, 17:52 -
Lame MP3 (or any MP3) in Sony Vegas 7
By boom731209 in forum AudioReplies: 7Last Post: 28th Oct 2010, 16:13
