Trying to do a simple autohotkey script to schedule recording in Avermedia RecCentral, But forgot how to use the programming language. What am I doing wrong? Thanks!Code:#singleinstance force #persistent Beginning: Gui, Add, Text,, Start Recording Time (24 hour time format) Gui, Add, Edit, vstarter, 19:00 Gui, Add, Text,, Stop Recording Time (24 hour time format) Gui, Add, Edit, vstopper, 21:00 Gui, Add, Button, Default, START Gui, Show return ButtonStart: Gui, Destroy Part: settimer, timer, 60000 ; check every minute return timer: formattime, time, , H:mm if (time = starter) { Send {F7} goto, Part } if (time = stopper) { settimer, timer, off Send {F7} msgbox, Recording Finished! } ExitApp
Results 1 to 13 of 13
ok, thanks to users Serenity and FlyingDman from autohotkey forums, here is the working script, I will compile the script to an exe and upload soon. Feel free to add an option to choose the day to record if you want. Currently, the recording has to start atleast 1 minute after the current time
Code:#singleinstance force #persistent Beginning: Gui, Add, Text,, Start Recording Time (24 hour time format) Gui, Add, Edit, vstarter, 19:00 Gui, Add, Text,, Stop Recording Time (24 hour time format) Gui, Add, Edit, vstopper, 21:00 Gui, Add, Button, Default, START Gui, Show return ButtonStart: Gui, submit looper: formattime, time, , H:mm if (time = starter) { Send {F7} starter = 25 goto, loopert } goto, looper sleep, 1000 loopert: formattime, time, , H:mm if (time = stopper) { Send {F7} goto, final } sleep, 1000 goto, loopert final: msgbox, Recording Finished!Last edited by ezcapper; 10th Jul 2015 at 11:34. Reason: fixed error in script
Here is an alpha version of ScheduleMyAver.exe It will let you schedule a recording if you use Aver RECentral
https://drive.google.com/file/d/0B695hmOChptNZGhqSzRYM1RtUWc/view?usp=sharing
bugs:
Recording time has to be set to atleast one minute after current time
RECentral must be running and ready before starting scheduler
You cannot choose a day to start the recording. It will start and end at the selected time.
Do not add 0's in front of time.
RECentral hotkey must be set to F7
once you get used to the complicated rules of using the program, you can use this simpler, smaller and neater looking version
https://drive.google.com/file/d/0B695hmOChptNQngxNEl1WGNXaDA/view?usp=sharing
I will change the simpler version soon to include a timed recording with an immediate start time optionLast edited by ezcapper; 10th Jul 2015 at 13:05.
ok, this version doesn't come with any directions, but you can use if you're familiar with how it works. Now you can do immediate recordings by putting 0 for the start time.
https://drive.google.com/file/d/0B695hmOChptNTERQM3QweU9sOFk/view?usp=sharing
bug:
Immediate recordings must be atleast 2 minutes
The next version will let you schedule the day. But won't be ready for a whileLast edited by ezcapper; 10th Jul 2015 at 13:27. Reason: Immediate recordings must be atleast 2 minutes
ok, now you might be able to set the recording day. You HAVE TO check the checkbox for the option to work. I have not tested this at all, so might or might not work.
alpha version
https://drive.google.com/file/d/0B695hmOChptNX28zN0x0ODZkV1k/view?usp=sharing
next version will allow you to exit the program without setting a recording time.
bugs:
will not work if you close program or turn off computer after setting record time
I have not tested the program, so don't know if it works.
There is a major bug in this version in that immediate recording is not working for some reason
source code
Code:#singleinstance force #persistent Beginning: Gui, Add, Text,, Start Gui, Add, Edit, vstarter, 9:00 Gui, Add, Text, ys, Stop Gui, Add, Edit, vstopper, 13:00 Gui, Add, Button, ys Default, SET Gui, Add, Checkbox, vdayter, Start Day Gui, Add, DropDownList, vlist, Monday|Tuesday|Wednesday|Thursday|Friday|Saturday|Sunday Gui, Add, Text,, Stop Day Gui, Add, DropDownList, vlist2, Monday|Tuesday|Wednesday|Thursday|Friday|Saturday|Sunday Gui, Show return ButtonSET: Gui, submit if list2 = { list2 = %list% list = %list2% } if dayter = 1 { temp2 = %list%%starter% starter = %temp2% temp = %list2%%stopper% stopper = %temp% } if (0 = starter) { goto, special } looper: if dayter = 0 { formattime, time, , H:mm } if dayter = 1 { formattime, time, , ddddH:mm } if (time = starter) { Send {F7} starter = 25 goto, loopert } sleep, 1000 goto, looper loopert: if dayter = 0 { formattime, time, , H:mm } if dayter = 1 { formattime, time, , ddddH:mm } if (time = stopper) { Send {F7} goto, final } sleep, 1000 goto, loopert special: Sleep, 1000 Send {F7} goto, loopert final: msgbox, Recording Finished! ExitAppLast edited by ezcapper; 10th Jul 2015 at 15:31.
ok, I would appreciate it if someone could test this version below and tell me which features work and which don't
https://drive.google.com/open?id=0B695hmOChptNMWJNOU5xSzA4RUU
1. To start an immediate recording, leave start time blank. Immediate recordings cannot last more than 24 hours.
2. scheduled recordings should start atleast 2 minutes after the current time.
3. No more checkbox, just fill whatever features you need. The only required field is what time to stop recording.
4. Do not put zeroes in front of times. (ex. 9:00, NOT 09:00) Times are based on 24 hour clock. So, 3 pm will be 15:00.
5. Avermedia RecCentral must be started and ready to use this add-on.
bug:
hitting the x button on the gui does not close the add-on
recording requires a working input source.
Code:#singleinstance force #persistent Beginning: Gui, Add, Text,, Start Gui, Add, Edit, vstarter, 9:00 Gui, Add, Text, ys, Stop Gui, Add, Edit, vstopper, 13:00 Gui, Add, Button, ys Default, SET Gui, Add, Checkbox, vdayter, Start Day Gui, Add, DropDownList, vlist, Monday|Tuesday|Wednesday|Thursday|Friday|Saturday|Sunday Gui, Add, Text,, Stop Day Gui, Add, DropDownList, vlist2, Monday|Tuesday|Wednesday|Thursday|Friday|Saturday|Sunday Gui, Show return ButtonSET: Gui, submit if starter = { Send {F7} msgbox, f7 sent dayter = 0 goto, loopert } if list2 = { list2 = %list% list = %list2% } if dayter = 1 { temp2 = %list%%starter% starter = %temp2% temp = %list2%%stopper% stopper = %temp% } looper: if dayter = 0 { formattime, time, , H:mm } if dayter = 1 { formattime, time, , ddddH:mm } if (time = starter) { Send {F7} starter = 25 goto, loopert } sleep, 1000 goto, looper loopert: if dayter = 0 { formattime, time, , H:mm } if dayter = 1 { formattime, time, , ddddH:mm } if (time = stopper) { Send {F7} goto, final } sleep, 1000 goto, loopert final: msgbox, Recording Finished! ExitAppLast edited by ezcapper; 10th Jul 2015 at 17:29.
ok, last one had a lot of bugs, so I gave up, here is a new format. last try.
For immediate recordings, leave start time blank. Only fill in the day if it is a different day.
https://drive.google.com/file/d/0B695hmOChptNd1RMdHliekQyN1U/view?usp=sharing
bugs:
recordings around midnight (0:00) might or might not work, I don't know.
maximum recording time is 24 hours.
once you are familiar with the add-on, you can use this smaller, slightly nicer looking version
https://drive.google.com/file/d/0B695hmOChptNUEdITFdxeGFzZkk/view?usp=sharing
sorry, claudio, the one I gave you access too has many bugs. You should be able to access these, which might work better. I still have sometimes it just doesn't work.
source code:
Code:#singleinstance force #persistent Beginning: Gui, Add, Text,, Start Recording Time (24 hour time format) Gui, Add, Edit, vstarter, 9:00 Gui, Add, Text,, Stop Recording Time (24 hour time format) Gui, Add, Edit, vstopper, 13:00 Gui, Add, Text,, Enter Day only if starting Recording on another day Gui, Add, DropDownList, vdayter, Monday|Tuesday|Wednesday|Thursday|Friday|Saturday|Sunday Gui, Add, Button, ys Default, START Gui, Show return ButtonStart: Gui, submit Working: if starter = { goto, finisher } if dayter = { goto, looper } checkday: sleep, 60000 formattime, time7, , dddd if time7 = %dayter% { goto, looper } goto, checkday looper: formattime, time, , H:mm if (time = starter) { Send {F7} starter = 25 goto, loopert } goto, looper sleep, 1000 loopert: formattime, time, , H:mm if (time = stopper) { Send {F7} goto, final } sleep, 1000 goto, loopert final: msgbox, Recording Finished! ExitApp finisher: Send {F7} goto, loopertLast edited by ezcapper; 10th Jul 2015 at 19:55.
ok, if someone can just post if any features on the last linked files DON'T WORK for them, otherwise I will use that as the (almost) final version of the add-on. I might make one other change next week, so when you hit the x button on the gui it closes the exe file.
Relax ezcapper,
I'm testing on all my systems (4 computers in total).
I got a C875 of my friend for testing.
So testing in all I answer.
Claudio -
https://drive.google.com/file/d/0B695hmOChptNajMxcndCQmg1UzA/view?usp=sharing
ok this probably the final version of the program I will upload unless there is a major bug. I know, the list of rules is way to long, but have to put them.
1. Now a tooltip pops up notifying what time you set the recording to. To permanently hide the tool tip, ctrl+alt+shift+h. The x button on the gui closes the app now. Alternately, to close the app, ctrl+alt+shift+e.
2. For immediate recordings, leave the start time blank. To schedule a recording to start on another day more than 24 hours from the current time, select the day from the drop down list, otherwise leave it blank.
3. I have not tested recordings starting at 0:00 (midnight), there might be a bug where these recordings don't start. Sorry, please use 11:59 or 12:01 instead, thanks. Times are in 24 hour format (ex. 14:00). Do not put an extra zero in front of the time (9:00 good, 09:00 bad).
4. Scheduled recordings should start atleast 2 minutes from the current time, otherwise use immediate recording, which should finish atleast 2 minutes after the current time. You can cheat on this, but then recording might or might not work, I have not tested.
5. Last few notes: The app uses the time on your computer. Avermedia RecCentral must be started and ready before actual recording starts. The program must be set on the default hotkey, which is F7. Valid input source must be plugged in before recording starts. If you have a typo in time, no recording.
Okay, if you survived all that. Would appreciate it if anyone let me know if there are any major bugs. Haven't tested the recording on different days. If no bugs, this might be the last post
Also let me know if anyone needs a version that will work with different hotkeys set in ReCentral. It is easy to make that feature customizable, but I was too lazy to do it. If you can compile it yourself and need just one different hotkey, just change F7 in the script to whatever.
source code
minor bug: tooltip has awkward phrasing on immediate recordings.Code:; <COMPILER: v1.1.22.02> #singleinstance force #persistent Beginning: Gui, Add, Text,, Start Recording Time (24 hour time format) Gui, Add, Edit, vstarter, 9:00 Gui, Add, Text,, Stop Recording Time (24 hour time format) Gui, Add, Edit, vstopper, 13:00 Gui, Add, Text,, Enter Day only if starting Recording on another day Gui, Add, DropDownList, vdayter, Monday|Tuesday|Wednesday|Thursday|Friday|Saturday|Sunday Gui, Add, Button, ys Default, START Gui, Show return ButtonStart: Gui, submit ToolTip, The recording will start at %starter% and finish at %stopper% on your selected day.,1920,0 Working: if starter = { goto, finisher } if dayter = { goto, looper } checkday: sleep, 60000 formattime, time7, , dddd if time7 = %dayter% { goto, looper } goto, checkday looper: formattime, time, , H:mm if (time = starter) { Send {F7} starter = 25 goto, loopert } goto, looper sleep, 1000 loopert: formattime, time, , H:mm if (time = stopper) { Send {F7} goto, final } sleep, 1000 goto, loopert final: msgbox, Recording Finished! ExitApp finisher: Send {F7} goto, loopert GuiClose: ExitApp ^!+e:: ExitApp ^!+h:: Tooltip,Last edited by ezcapper; 11th Jul 2015 at 12:04.
I forgot to mention that if you are away from your computer you can schedule a recording through the add-on using your smartphone with the chrome remote desktop app.
Experimental Revision
https://drive.google.com/file/d/0B695hmOChptNeTA0OFZVaU9GOXc/view?usp=sharing
changes:
tooltip turns off when recording starts
tooltip does not display on immediate recordings.
I added this experimental revision to make it easier to schedule ReCentral recordings from your smartphone (see post above). Might make future changes to make it more easy, like operation without using the mouse pointer.
The first time I posted this version, it was non-working, I took it down within a couple minutes of the post, but if you downloaded, sorry about that and please try again.Last edited by ezcapper; 12th Jul 2015 at 22:56. Reason: added experimental revision
Yes I am recording HDMI HDCP over Avermedia LGP Lite Capture- simple
By BobbyGee in forum Capturing and VCRReplies: 8Last Post: 19th Sep 2014, 06:54 -
Simple mp4 edit program?
By WBFAir in forum EditingReplies: 9Last Post: 28th Aug 2013, 09:03 -
Software to capture video from Capturer that support Schedule recording?
By Anonymous847344 in forum Capturing and VCRReplies: 17Last Post: 24th Mar 2013, 11:06 -
Program for simple editing and burning
By hodocka in forum Newbie / General discussionsReplies: 7Last Post: 24th Jan 2011, 22:16 -
Simple DV capture program
By HDClown in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 12th Jul 2010, 08:49
