  1. As I understand it, the current HEVC spec supports alpha channel (as 'Auxiliary Pictures'). Is there an encoder which implements that functionality? I don't believe x265 does. Atleast, the latest ffmpeg build doesn't accept yuva420p as output format.
  2. I don't know about that. The files BPG also don't have the alpha channel. The alpha channel have the files JPG.
  3. Member Cornucopia's Avatar
    Don't know what your trying to say here, @Jamaika...
    BPG format spec DOES support alpha (see http://bellard.org/bpg/), doesn't mean any particular encoded file has it, nor that a particular implementation of the codec supports it.
    JPG does not support transparency/alpha (without resorting to an odd, rare hack). And using JPG's DCT/block compression on an alpha channel is probably the worst thing you can do to its utility as an alpha.
    @Gyan, I'm pretty sure that at this time there is NOT an encoder that implements this.
  4. Scott, including the reference encoder HM? I scanned the manual but am not sure if I missed it.
  5. Member Cornucopia's Avatar
    Wasn't talking about reference encoder, but I also don't see anything pertinent at all about "alpha", "transparent", "transparency", "channel" or "mask" there, so I doubt it is helpful either. Check a branch, though. (that's also where you should find the 3D extensions)
  6. Originally Posted by Cornucopia View Post
    I see alpha canal. I'm using version 0.9.5: bpgenc.exe -h. The alpha canal work if the import file has it.
    -alphaq              set quantizer parameter for the alpha channel (default = same as -q value)
    I'm sorry made a mistake. JPG use channel K.
