I want to encode videos that are upscaled and I want to use ffdshow video encoder, but I need an CLI or any software that will function with the external encoder. Is there way to encode videos with ffdshow filter or not possible?
	I remember being able to do this in earlier versions (WinXP) of Windows using Virtualdub or Vegas, but it doesn't seam to work in Win 8.1. Got my retirement plans all set. Looks like I only have to work another 5 years after I die........
	It is not clear what is your intention but ffdshow can be used trough different way and by different software - for example Avisynth , VirtualDub(Mod).
	It is possible to use ffdshow's VfW codecs to encode a video stream with a CLI tool, e.g. avs2avi (call it once to configure the VfW codec and save a profile file, then re-use that in the following encodes); but you could as well use ffmpeg as CLI encoder, it should have the same encoders implemented. Furthermore, it is possible to control VirtualDub with jobs to load a source, configure a codec, and write a new AVI.
  is there a VFW decoder for mpg2 FOURCC ? (not ffdshow)By marcorocchini in forum Newbie / General discussionsReplies: 0Last Post: 14th Dec 2014, 12:47
  Capture software for video capture cards that allow to use external filtersBy Milardo in forum Capturing and VCRReplies: 7Last Post: 9th May 2013, 00:35
  ffdshow VFW Conf won't open-RunDLL errorBy shokan22 in forum Newbie / General discussionsReplies: 3Last Post: 24th Mar 2013, 11:01
  after conversion movie's shape is strange using VFW Codec with ffdshowBy ggdn in forum Video ConversionReplies: 2Last Post: 6th Aug 2012, 03:30
  VFW ffdshow Settings to Edit flv in VdubBy kaskaï in forum Newbie / General discussionsReplies: 15Last Post: 1st Jun 2011, 12:40
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
