I downloaded VLC for Mac and when I try and save a clip for editing from a DVD, the video plays without audio and when the video ends, the audio starts playing.This remains the same when transferred as well. Does anyone have any tips on how to fix this??
Is this from a commercial/retail DVD? If so, you might try ripping the DVD before attempting to use VLC to transcode (use VLC to transcode from the rip, not the DVD itself, in other words).
Just to be safe, you might also use one of the OS X variants of MediaInfo, like VideoSpec or iMediaHUD, for example, to show information about the result video, and cut-and-paste the information here for others to examine. VLC has its own feature for showing such information, but it tends to be limited. Just make sure the app you're using to get information shows as much info as possible before copying it to show here (usually text/tree mode in MediaInfo itself, the other apps probably vary.)
Does the video play with the same results in any other player?If cameras add ten pounds, why would people want to eat them? -
How are you saving the video from the DVD?
Have you tried to play the clip on other players?
Does this problem happen with all DVDs?
I assume you have done this before.
Some DVDs have multiple audio tracks.
Not enough information to say why the synch is off so far.
And welcome to our forums.
Struggling with Video Quality (YouTube)
By midiout in forum Video Streaming DownloadingReplies: 46Last Post: 30th Jun 2015, 19:35 -
Struggling to convert a video the way I want
By docodine in forum Video ConversionReplies: 2Last Post: 9th May 2014, 02:18 -
VLC:How can I add new/outer fitler or decoders to VLC?
By dayangwc in forum Newbie / General discussionsReplies: 2Last Post: 12th Jul 2013, 06:33 -
Struggling to convert a VOB file
By mreco99 in forum Video ConversionReplies: 8Last Post: 8th May 2013, 16:42 -
Struggling with Panasonic HDC-SD5
By khan.cross in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 15Last Post: 5th Aug 2010, 15:49
