I often find that I need to turn both the Windows volume & the Potplayer volume all the way up when playing back video in Potplayer.
The "Boost Audio" function generally causes too many harsh glitches & crackles to use.
When I playback music, for example, in iTunes I never need to go past 50% Windows volume.
Is there something I can do to increase the audio output in Potplayer?
I suppose you've ticked Enable in Preferences - Audio - Normalizer/Freeverb.
Can you check, if the volume level is low in all video files? If not, see what audio codec they use (aac, ac3, etc) and in what container (mp4, mkv, etc) plus what decoder/filter your PotPlayer uses.
If the audio is ac3, you might go to Preferences - Audio - Volume Control and tick 'Pre-amplify AC#/DTS Vol.' (if your PotPlayer uses internal decoders). If you use AC3Filter you might fiddle with settings in its settings (ask google 'ac3+low audio volume' or something like that). -
Generally the files I play are MP4 or MKV using AC3 or ACC.
I am using Lav Filters.
I did have Normalizer/Freeverb checked. But actually when I uncheck it the audio in general seems to increase a decent bit.
I tried the Pre-amplify AC#/DTS Vol, but the audio gets a bit distorted. -
Potplayer is a bit cumbersome when it comes to audio preferences as there are so many different menus and views.
the best way to increase audio volume that I have found is this:
Increase master volume as much as you want until it starts to sound distorted. Shouldn't need more than 150%.... -
Thanks this helped me, I guess VLC is no use for me anymore. Pot Player has so many features.
Low volume when loading external audio file in VD
By danswano in forum Video ConversionReplies: 13Last Post: 27th Jul 2013, 07:28 -
Dialogue Volume in LCD TV is low while action/music volume is high
By Biker Biker in forum DVB / IPTVReplies: 4Last Post: 2nd Mar 2013, 01:41 -
Is it true that if I capture on low volume then the Audio will be better?
By gil900 in forum AudioReplies: 22Last Post: 16th Feb 2013, 10:03 -
DVD audio volume too low
By efiste2 in forum AudioReplies: 4Last Post: 28th Mar 2012, 16:06 -
Ripbot Flac for Audio - volume too low
By AndyD in forum Blu-ray RippingReplies: 2Last Post: 10th Sep 2010, 19:55
