Thanks in advance for advice.
Could anyone say for sure why it is Bluray software must connect to a server for ??? proberbly some info before playing the disc? DVD software does not appear to do that!
Can't you play it at all without internet? What player?
No the software eg ANYDVD, DVD fab, Leawo Blu-ray Player always want to connect to a server, i simply dont understand why though. DVD only software I use never wants to connect to a server. Always have to be connected to the internet for playing bluray. If someone can recommend software that does not require internet connection then please advise!
According to something I found on the AnyDVD forum, the Blu-Ray software probably needs to access an online database to decrypt your Blu-Ray disc because it is using an unfamiliar BD+ copy protection method. Handling the situation by going online to access the database is the quickest way to solve the problem. See this post and the one that follows it.
BD+ is constantly evolving. DVD copy protection schemes don't change much.
Free bluray converter to h.265(convert your 25GB bluray film to just 500mb)
By david55 in forum Video ConversionReplies: 3Last Post: 4th Nov 2014, 11:15 -
How to FF or search a movie played from BluRay's USB
By chinchilla in forum Blu-ray RippingReplies: 5Last Post: 7th Aug 2012, 19:38 -
How to shrink a 50GB-BLURAY-movie to fit on a 25GB-BLURAY disc ?
By kulmagen in forum DVD RippingReplies: 31Last Post: 1st Feb 2012, 13:39 -
google search pages keeps erasing my search criteria -- [RESOLVED]
By vhelp in forum ComputerReplies: 0Last Post: 5th Mar 2011, 16:27 -
True PAL 1080i 25fps Bluray -> native 1080p 24fps Bluray?
By BilboFett in forum Blu-ray RippingReplies: 1Last Post: 27th Feb 2011, 11:29
