A third of my mkv collection is not working on my TV but work properly everywhere else. It's a LG 37LS5600*. I'm using Handbrake to convert them to MKV, with always the same settingH264 - same as source)(Constant quality @19RF)(H264 Preset=fast)(Tune=Film)(Fast decode=uncheck)(H264 profile=auto)(H264 Level=auto).
Any hints on what going on and what would be the best setup for this TV.
TV: Max 1920x1080 @ 30fps : H264/AVC Profile Level 4.1 and lower : MKV= H264/AVC, Xvid,Mpeg-4 part2 : Sound= He-AAC,Dolby Digital,Mpeg1 Layer3
Thanks all.
Results 1 to 9 of 9
No, I use (Codec=ACA (FAAC) (Bitrate=160) (Sample rate = AUTO) . Cause I saw on the web that DTS is problem with TV.
Thanks -
is it the audio or the video
do you have link to the TV specs
my personal limited experience.. is TVs do not list MKV in their compatible formats
MKV is just a wrapper, use something else like MP4 -
Thanks guys, I'll try MKV2MP4 as per Cauptain said and see. I did try a lot of setting in Handbrake with Quality, Profile, Level, but still in problem. I have 2 films that have 2 versions (One work, but not the other one) so I will take a look at the specs of those 2 mkv films to see if there 's a difference somewhere.
I will use MediaInfo and MkvInfo. If you have a better idea......I'm open. Bye -
I load the MKV2MP4 and I see lots of setups. What would be the proper setup for me. I just want to put the 2 audio tracks in AC3, with same quality and # of channels as the input. And as for video it should be as input.
But for now, I can't have the output file. Here's the end of the log:
[Win32] system failure for file opening of D:/Internet Download/Mp4Box\005C4098_isotmp in mode w+b: 0x00000003
Cannot open destination file D:/Internet Download\L'enlevement 2 - Taken 2 - action (NO).mp4: I/O Error
Mp4Box terminated with error: 1
Total time: 5 min. 58 sec.
0 files processed.
1 errors.
In this folder I can see the MkvToMp4 files : (2x .AAC)(1x .264)( 2x .WAV)(2X M4A)(1x .TXT) meaning that this folder is OK
I'm on Windows Xp Sp3.
Thanks at advance. -
Google is your Friend
What to do when Image Sequencing don't worK?
By KneeRow in forum Video ConversionReplies: 11Last Post: 5th Aug 2013, 14:08 -
Mux Righteye hs64 file to mkv don´t work
By PsyDonias in forum Video ConversionReplies: 4Last Post: 8th Jul 2012, 11:30 -
Add audio don't work on ffmpegX
By petwes in forum ffmpegX general discussionReplies: 1Last Post: 28th Jan 2012, 04:51 -
CUDA don't work, why?
By lovelylisa in forum Video ConversionReplies: 38Last Post: 24th Jun 2011, 17:19 -
BD Sup to srt and why they don't work all that weLL.
By cal_tony in forum SubtitleReplies: 2Last Post: 4th May 2011, 10:17
