hi guys im trying to send video output of laptop to tv via normal rf cable ,,im using karaoke software on laptop and i want to send signal to external screen but i only have vga output
	You need a scan converter (VGA to composite) and an RF modulator (composite to RF). Keep in mind that the quality of standard definition video is very low compared to VGA. Around 480x576 pixels for PAL. You will barely be able to read normal sized computer text. And the cheap scan converters suffer from tearing.
	Does the TV have any input connections other than RF? Is this an old standard definition CRT TV with an analog tuner?
 If you use the TVs RF connection, then you need to create a compatible signal for the TV tuner. It would be considerably less expensive to buy a new TV with a VGA connection than to buy a device to create that kind of signal for a digital TV.
 If the TV is an old analog CRT, then it might be possible to cobble something together for less money (although still close to the price of a TV), but the picture quality would be poor. Also only large text in a picture that has been down-scaled from laptop resolutions will be readable.
	I posted some samples of VGA to composite video quality a while back:
 https://forum.videohelp.com/threads/283861-VGA-to-S-video?p=1756748&viewfull=1#post1756748
  Outlook not sending email with attachmentsBy Squid_uk in forum ComputerReplies: 25Last Post: 12th Oct 2013, 03:09
  Difficulty sending videos to Iphone.By hellfire45 in forum Video ConversionReplies: 2Last Post: 2nd Jan 2012, 03:58
  Sending MP4 from UK to USABy terrypin in forum Newbie / General discussionsReplies: 5Last Post: 5th Oct 2011, 14:54
  Sending video from my computer to TV?By NeWcS in forum ComputerReplies: 26Last Post: 16th Jul 2011, 11:16
  Sending a signal from CableboxBy karl333 in forum DVB / IPTVReplies: 12Last Post: 2nd Nov 2010, 18:03
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
