    Jul 2015
    Coolzone
    Any body knows how to use this reclock? I found this site https://github.com/zachsaw/MPDN_Extensions/wiki/Rate-Tuner. From my understanding it can replace reclock. There is instructions saying how to use it but where can I find this rate tuner thingie? How can I use it? Where to begin?!
    Thx!
    Jul 2009
    Australia
    Hi beanies,
    Rate Tuner is an extension for MPDN (Media Player .NET). MPDN is a media player that looks similar to MPC-HC but it's been written from the ground up with .NET. To use Rate Tuner, you'll need to use MPDN.
    MPDN has a built-in GPU video renderer that has been setting the trend for madVR's new features (10-bit output, DX11, NEDI scaler, SuperRes, 64-bit etc.). What you've stumbled upon is the open source portion of MPDN called MPDN Extensions - i.e. plugins.
    If you want a bit more information on the Rate Tuner plugin specifically, have a read here.
    Have fun!
    Cheers.
    * Disclaimer: I'm the author of MPDN.
