    Jun 2015
    California
    When I got the VC500 it came with Ezgrabber and Showbiz movie editing software, I noticed Showbiz also has a capture feature. Is there any advantages to using one over the other?
    Thanks!
    Aug 2006
    Thanks!
    I never tried Ezgrabber. I did try a customized version of Showbiz that came with a high-definition capture device I bought. Showbiz was fine, but the device had its own onboard encoder and all Showbiz had to do was write its output to my hard drive. I have no idea how well Showbiz performs with devices that use Showbiz for encoding.
    You will have to try them both to see which you like best.
    Jun 2015
    California
    Thanks usually_quiet, I forgot to mention I also have Corel Videostudio X7 which also has a capture feature. I better get hands on busy. I'm sure I'll be back with more questions.
    Thanks.
  4. Does virtualdub work with this device. Some of these type of dongle things work in virtualdub and you can change the encoder to huffyuv to capture lossless. I had an easycap one that did that
