  1. When I try to rip this live stream, it works fine until after a random number of minutes, when I get the error PES packet size mismatch and it stops. My internet connection/bandwith/ping is fine. When I play the stream in VLC, it doesn't stop either or gives an error or messed up image. What is causing this?
    E:\ffmpeg>ffmpeg -i "http://185.70.130.89:1234/udp/239
    .0.0.183:1234" -map 0:0 -map 0:1 -map 0:2 -c:v copy -c:a copy output.ts
    ffmpeg version N-72981-gdc87758 Copyright (c) 2000-2015 the FFmpeg developers
      built with gcc 4.9.2 (GCC)
      configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-av
    isynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enab
    le-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --
    enable-libdcadec --enable-libfreetype --enable-libgme --enable-libgsm --enable-l
    ibilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enab
    le-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --en
    able-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --ena
    ble-libtwolame --enable-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc
     --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enabl
    e-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-lzma --ena
    ble-decklink --enable-zlib
      libavutil      54. 27.100 / 54. 27.100
      libavcodec     56. 41.100 / 56. 41.100
      libavformat    56. 36.100 / 56. 36.100
      libavdevice    56.  4.100 / 56.  4.100
      libavfilter     5. 17.100 /  5. 17.100
      libswscale      3.  1.101 /  3.  1.101
      libswresample   1.  2.100 /  1.  2.100
      libpostproc    53.  3.100 / 53.  3.100
    [h264 @ 0498e240] non-existing PPS 0 referenced
        Last message repeated 1 times
    [h264 @ 0498e240] decode_slice_header error
    [h264 @ 0498e240] no frame!
    [mpegts @ 0498bfe0] PES packet size mismatch
    [h264 @ 0498e240] left block unavailable for requested intra4x4 mode -1 at 0 24
    [h264 @ 0498e240] error while decoding MB 0 24, bytestream 36291
    [h264 @ 0498e240] mmco: unref short failure
    [h264 @ 0498e240] number of reference frames (0+5) exceeds max (4; probably corr
    upt input), discarding one
    [h264 @ 0498e240] Reference 3 >= 2
    [h264 @ 0498e240] error while decoding MB 16 55, bytestream 900
    Input #0, mpegts, from 'http://185.70.130.89:1234/udp/239.0.0.183:1234':
      Duration: N/A, start: 732.508411, bitrate: N/A
      Program 14106
        Metadata:
          service_name    : ?Nickelodeon HD
          service_provider: ?HTB+
        Stream #0:0[0x146]: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p(tv,
     bt709), 1920x1080 [SAR 1:1 DAR 16:9], 25 fps, 50 tbr, 90k tbn, 50 tbc
        Stream #0:1[0x196](rus): Audio: ac3 ([6][0][0][0] / 0x0006), 48000 Hz, stere
    o, fltp, 384 kb/s (clean effects)
        Stream #0:2[0x1a0](eng): Audio: ac3 ([6][0][0][0] / 0x0006), 48000 Hz, stere
    Output #0, mpegts, to 'output.ts':
      Metadata:
        encoder         : Lavf56.36.100
        Stream #0:0: Video: h264 ([27][0][0][0] / 0x001B), yuv420p, 1920x1080 [SAR 1
    :1 DAR 16:9], q=2-31, 25 fps, 50 tbr, 90k tbn, 25 tbc
        Stream #0:1(rus): Audio: ac3 ([6][0][0][0] / 0x0006), 48000 Hz, stereo, 384
        Stream #0:2(eng): Audio: ac3 ([6][0][0][0] / 0x0006), 48000 Hz, stereo, 384
    Stream mapping:
      Stream #0:0 -> #0:0 (copy)
      Stream #0:1 -> #0:1 (copy)
      Stream #0:2 -> #0:2 (copy)
    Press [q] to stop, [?] for help
    frame=  245 fps=0.0 q=-1.0 size=    2894kB time=00:00:06.72 bitrate=3525.0kbits/
    frame=  275 fps=258 q=-1.0 size=    3264kB time=00:00:07.32 bitrate=3649.4kbits/
    frame=  303 fps=185 q=-1.0 size=    3565kB time=00:00:07.88 bitrate=3703.4kbits/
    frame=  329 fps=151 q=-1.0 size=    3938kB time=00:00:08.40 bitrate=3837.7kbits/
    frame=  359 fps=131 q=-1.0 size=    4240kB time=00:00:09.00 bitrate=3856.4kbits/
    frame=  383 fps=117 q=-1.0 size=    4597kB time=00:00:09.48 bitrate=3969.5kbits/
    frame=  415 fps=108 q=-1.0 size=    4944kB time=00:00:10.12 bitrate=3999.6kbits/
    frame=  440 fps=100 q=-1.0 size=    5285kB time=00:00:10.62 bitrate=4074.2kbits/
    frame=  468 fps= 94 q=-1.0 size=    5635kB time=00:00:11.18 bitrate=4126.5kbits/
    frame=  499 fps= 90 q=-1.0 size=    6050kB time=00:00:11.80 bitrate=4197.6kbits/
    frame=18019 fps= 51 q=-1.0 size=  262138kB time=00:06:02.20 bitrate=5928.8kbits/
    frame=18055 fps= 51 q=-1.0 size=  262480kB time=00:06:02.92 bitrate=5924.7kbits/
    frame=18082 fps= 51 q=-1.0 size=  262923kB time=00:06:03.46 bitrate=5925.9kbits/
    frame=18111 fps= 51 q=-1.0 size=  263329kB time=00:06:04.04 bitrate=5925.6kbits/
    frame=18135 fps= 51 q=-1.0 size=  263695kB time=00:06:04.52 bitrate=5926.0kbits/
    frame=18162 fps= 51 q=-1.0 size=  264122kB time=00:06:05.06 bitrate=5926.8kbits/
    frame=18183 fps= 51 q=-1.0 size=  264414kB time=00:06:05.48 bitrate=5926.6kbits/
    frame=18208 fps= 51 q=-1.0 size=  264824kB time=00:06:05.98 bitrate=5927.6kbits/
    frame=18231 fps= 50 q=-1.0 size=  265298kB time=00:06:06.44 bitrate=5930.8kbits/
    frame=18255 fps= 50 q=-1.0 size=  265569kB time=00:06:06.92 bitrate=5929.1kbits/
    frame=18266 fps= 50 q=-1.0 Lsize=  266137kB time=00:06:07.14 bitrate=5938.2kbits
    /s
    video:207880kB audio:34305kB subtitle:0kB other streams:0kB global headers:0kB m
    uxing overhead: 9.889907%
  2. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Try record directly from VLC.
    I record some stream from chaturbate via VLC and its OK four hours. No crash.
    Claudio
