I have some *.mov and *.mp4 movies from Itunes (without DRM). And I need to cut video, audio and subtitles with one software. I have tried TMPGEncd Smart Renderer 4, Avi Split Media but they can't load the subtitles. What software can you recommend me? Thank you very much.
You could try putting the files in a MKV container - use MKVMergeGui and drag the file into it. You should then see the video, audio and subtitle listed. As long as the subtitle is text format ie srt and not image based as on commercial DVD's you should be able to split the file on time designated locations.
There isn't an editor as such built in but you can split the file by time, not frame accurate like an editor with a time line.... Then remux - no processing so no loss of quality.SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
I have tried MKVMergeGui but it doesn't load the subtitles. The subtitles are: "Timed Text" (muxing mode: SBTL, ID Code: tx3g)
You can de-mux with MyMP4box Gui. The subtitles then will be .srt that can be brought into MKVMerge GUI
(There is also a splitter function in MYMP4Box GUI)Last edited by videobruger; 7th Jul 2015 at 05:48. Reason: addendum
You can cut the file in this way:
https://youtu.be/IRYAvTyUNog -
Thanks for the help. MyMP4box works perfect for obtain the subtitles, after with MkvMerge I muxed video, audio and subtitles in a new mkv file but when I want to make the cuts I got an error.
Then I use SolveigMM Splitter with the mkv file and works cutting video, audio and subtitles quite well.
How to edit video files with subtitles by SolveigMM Video Splitter
By DmitryV in forum User guidesReplies: 0Last Post: 9th Jun 2015, 10:33 -
What software will edit audio/video without quantizing to frames?
By Lakevid in forum EditingReplies: 1Last Post: 14th Feb 2015, 18:58 -
video edit software question
By mrs.faith in forum Newbie / General discussionsReplies: 7Last Post: 11th Dec 2014, 18:33 -
Software to edit/cut/merge/convert MKV audio and video @ original bitrates
By Yanta in forum Video ConversionReplies: 9Last Post: 19th Oct 2014, 16:11 -
light software to edit video
By mathmax in forum EditingReplies: 1Last Post: 6th Dec 2010, 04:45
