[2015-07-06 2-30-27 PM] - Job #1
MediaInfo
General
Unique ID : 0 (0x0)
Complete name : D:\Videos\Anime\[HorribleSubs] DanMachi [1080p]\[HorribleSubs] DanMachi - 03 [1080p].mkv
Format : Matroska
Format version : Version 2
File size : 542 MiB
Duration : 23mn 41s
Overall bit rate : 3 197 Kbps
Encoded date : UTC 2010-02-22 21:41:29
Writing application : no_variable_data
Writing library : no_variable_data
Attachment : Yes
Video
Format : AVC
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Muxing mode : Header stripping
Codec ID : V_MPEG4/ISO/AVC
Duration : 23mn 41s
Nominal bit rate : 3 072 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.062
Writing library : x264 core 120 r2120 0c7dab9
Encoding settings : cabac=1 / ref=4 / deblock=1:1:1 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=0.40:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=8 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=3072 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=6144 / vbv_bufsize=15360 / nal_hrd=none / ip_ratio=1.40 / aq=1:0.60
Default : Yes
Forced : No
Audio
Format : AAC
Format profile : LC
Codec ID : A_AAC
Duration : 23mn 41s
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Compression mode : Lossy
Default : Yes
Forced : No
Text
Format : ASS
Codec ID : S_TEXT/ASS
Codec ID/Info : Advanced Sub Station Alpha
Compression mode : Lossless
Default : Yes
Forced : No
[2015-07-06 2-30-27 PM] Task #01 : Indexing
Index Caches Detected
[2015-07-06 2-30-27 PM] Task #02 : Extracting Subtitles
Running Tool: "C:\Users\Jeroen\Desktop\Vafe 13 (2013.07.18.06)\tools\MKVToolnix\mkvextract.exe"
Parameters: tracks "D:\Videos\Anime\[HorribleSubs] DanMachi [1080p]\[HorribleSubs] DanMachi - 03 [1080p].mkv" 2:"C:\Users\Jeroen\Desktop\Vafe 13 (2013.07.18.06)\temps\subtrack1.ass"
Extracting track 2 with the CodecID 'S_TEXT/ASS' to the file 'C:\Users\Jeroen\Desktop\Vafe 13 (2013.07.18.06)\temps\subtrack1.ass'. Container format: SSA/ASS text subtitles
ExitCode: 0
Task finished successfully
[2015-07-06 2-30-32 PM] Task #03 : Extracting Internal Attachments
Parameters: attachments "D:\Videos\Anime\[HorribleSubs] DanMachi [1080p]\[HorribleSubs] DanMachi - 03 [1080p].mkv" 1:"C:\Users\Jeroen\Desktop\Vafe 13 (2013.07.18.06)\temps\OpenSans-Semibold.ttf"
The attachment #1, ID 1, MIME type application/x-truetype-font, size 221328, is written to 'C:\Users\Jeroen\Desktop\Vafe 13 (2013.07.18.06)\temps\OpenSans-Semibold.ttf'.
ExitCode: 0
[2015-07-06 2-30-32 PM] Task #04 : Cleaning Font Caches 1/2
Running Tool: "C:\Users\Jeroen\Desktop\Vafe 13 (2013.07.18.06)\tools\TH3K31CLITools\FontLoaderCLI .exe"
Parameters: -unload -folder "C:\Users\Jeroen\Desktop\Vafe 13 (2013.07.18.06)\fontcaches"
Terminated: Folder "C:\Users\Jeroen\Desktop\Vafe 13 (2013.07.18.06)\fontcaches" doesn't contain any font file
ExitCode: 0
[2015-07-06 2-30-32 PM] Task #05 : Cleaning Font Caches 2/2
Deleted Contents of Folder: "C:\Users\Jeroen\Desktop\Vafe 13 (2013.07.18.06)\fontcaches"
[2015-07-06 2-30-32 PM] Task #06 : Caching Font
Copied File "C:\Users\Jeroen\Desktop\Vafe 13 (2013.07.18.06)\temps\OpenSans-Semibold.ttf" To "C:\Users\Jeroen\Desktop\Vafe 13 (2013.07.18.06)\fontcaches\OpenSans-Semibold.ttf"
[2015-07-06 2-30-33 PM] Task #07 : Loading Font For Subtitles Hardcoding
Parameters: -load -folder "C:\Users\Jeroen\Desktop\Vafe 13 (2013.07.18.06)\fontcaches"
Working Mode : Font Loading.
Source : Folder "C:\Users\Jeroen\Desktop\Vafe 13 (2013.07.18.06)\fontcaches"
Total Fonts :
Total Fonts : 1
Processed: 1/1 file(s)
ExitCode: 0
[2015-07-06 2-30-33 PM] Task #08 : Writing Video Script
Writing File: "C:\Users\Jeroen\Desktop\Vafe 13 (2013.07.18.06)\temps\video.avs"
Content
LoadPlugin("C:\Users\Jeroen\Desktop\Vafe 13 (2013.07.18.06)\tools\avisynth\ffms2.dll")
FFVideoSource("D:\Videos\Anime\[HorribleSubs] DanMachi [1080p]\[HorribleSubs] DanMachi - 03 [1080p].mkv",timecodes="C:\Users\Jeroen\Desktop\Vafe 13 (2013.07.18.06)\temps\timecodesv2.txt",cachefile=" C:\Users\Jeroen\Desktop\Vafe 13 (2013.07.18.06)\indexcaches\b58f1fb1a04ad36c52e2d8 d426ccb8c8\b58f1fb1a04ad36c52e2d8d426ccb8c8.ffinde x", utf8=true,threads=1) #<typeource><handletc>
ConvertToYV12()
LanczosResize(960,544)#<mark:deform>
#Hardsub From Here
[2015-07-06 2-30-34 PM] Task #09 : Collecting Video Output Info Step 1/2
Running Tool: "C:\Users\Jeroen\Desktop\Vafe 13 (2013.07.18.06)\tools\TH3K31CLITools\AVSChecker.ex e"
Parameters: -i "C:\Users\Jeroen\Desktop\Vafe 13 (2013.07.18.06)\temps\video.avs" -o "C:\Users\Jeroen\Desktop\Vafe 13 (2013.07.18.06)\temps\videoinfo.txt"
Analyzing C:\Users\Jeroen\Desktop\Vafe 13 (2013.07.18.06)\temps\video.avs ...
Avisynth open failure:FFVideoSource: The index do
Avisynth open failure:FFVideoSource: The index does not match the source file
(C:\Users\Jeroen\Desktop\Vafe 13 (2013.07.18.06)\temps\video.avs, line 2)
ExitCode: 4294967295
Task got errors
How do I fix this? I try to convert mkv to mp4.
Results 1 to 9 of 9
is the file FFVideoSource shall load.Code:
will be the matching index file. Delete it. Maybe by pressing the "Del" key on your keyboard when this file is selected in your Windows Explorer.Code:C:\Users\Jeroen\Desktop\Vafe 13 (2013.07.18.06)\indexcaches\b58f1fb1a04ad36c52e2d8d426ccb8c8\b58f1fb1a04ad36c52e2d8d426ccb8c8.ffindex
If this index name is generated randomly on each run of this software, it may be hard to track down anyway... possible that my suggestion already came too late, the next run may have a different result.Last edited by LigH.de; 6th Jul 2015 at 13:27. Reason: CODE around bandworm file names
Hint: use 'code'-tagsGrrr, what a worm of a file name. This board software keeps inserting spaces on its own.
users currently on my ignore list: deadrats, Stears555, marcorocchini -
Some programs have problems with particular characters in file names. Try renaming the files without square brackets. Or any other non-alphanumeric or foreign characters.
@ jagabo: The error is related to the index file, not the media file. And the index file name is completely alphanumerical.
Just the location is nonsense (on the desktop); but well, IMHO.
Weird Handbrake error Version 10.1
By fighuass in forum Video ConversionReplies: 73Last Post: 30th Mar 2015, 02:10 -
Weird SD 4:3 and 16:9 Clip - How to display it properly via Avisynth?
By VideoFanatic in forum RestorationReplies: 42Last Post: 6th Jan 2015, 12:20 -
Weird Brightness Problem - How to fix with Avisynth?
By VideoFanatic in forum RestorationReplies: 20Last Post: 4th Apr 2012, 08:10 -
Weird Error message
By SIRCOOKS in forum ComputerReplies: 5Last Post: 27th Sep 2011, 11:30 -
Sudden RipBot error (avisynth error)
By Charles314 in forum DVD RippingReplies: 5Last Post: 24th Oct 2010, 02:44
ource><handletc>
