Hi,
After having parked my VHS archival project due to a series of personal events, I have finally come back to it and have encountered some problems with my new set up.
My new set up is the following (based in UK-PAL)
JVC HR-S8600EK S-VHS player with TBC/NR (I also have a damaged JVC BR-S525 and a Pana HS-121)
AVT-8710 TBC (s-video cables in and out)
BlackMagic Design Intensity Shuttle USB 3.0
Windows 8.1 64bit PC based on Intel Core i7-3770K CPU, Asus P8Z77-V PRO Motherboard, 32GB RAM, 240GB SSD (Software) and 2x 1TB HDD RAID for capture
Adobe Premier Pro and BM Media Express for Capture and PrePro for editing.
My main objective is to transfer family home videos shot from 1988 to approx. 1999 and the occasional TV recording (family and friends that appeared in TV shows in those years) to digital format for restoration and archival. The first stage is to record and then trim any non-wanted footage (most Camera captures are at the beginning, middle or end of VHS tapes with other recording- we were teenagers then.). Some tapes are top quality and bought and used for main events (wedding, first communions, etc), others are cheap, non-branded tapes, used multiple times…
Workflow: Capture in BM 10 bit uncompressed 4:2:2 YUV (AVI) and trim in Adobe Premiere. So far so good. I than render and export, in “same as source” mode, but I am encountering two issues:
1- The sum of three clips, total 29 minutes = sum of 33gb files (adding the individual clips sizes) becomes a 40+gb file after encoding
2- The output has interlaced artifacts not visible in the captured clips. I have searched the web and already checked that the setting of project, source and output (same as source) are the same. If I play the original capture in Quick time, Microsft Media Player, etc, there are no combing artefacts. However, these appear in the rendered/encoded file.
As I live in another country and brought with me all the tapes, and will soon visit the family back home, I would like to at least return the initial trimmed transfer in probably an AVCHD disk format (basically an H.264 compressed Gold DVD archival grade playable in a Blu Ray player) on my forthcoming visit. I will then spend some time to restore each transferred tape with the various Virtyual Dub filters and probably try some After Effects Color Correction (Red Giant Magic Bullets Plug Inns) and Up scaling (Either Red Giant Instant HD or Infognition's Video Enhancer)
Can someone help?
"same as source" doesn't always work . Double check that :
1) the files are interpreted as interlaced with the correct field order (upper or lower , whatever your files actually are)
2) sequence settings have the same interpretation
3) export settings have the same interpretation
The different filesize suggests a problem, or that you're not using the same input format as output. Use mediainfoxp and check (view=>text) on an input file , and an output file copy the text view back here -
Original File
General
Complete name : E:\My Videos\PrePro\1991 second capture.avi
Format : AVI
Format profile : OpenDML
File size : 29.3 GiB
Duration : 24mn 52s
Overall bit rate : 169 Mbps
Video
Format : YUV
Codec ID : UYVY
Codec ID/Info : Uncompressed 16bpp. YUV 4:2:2 (Y sample at every pixel, U and V sampled at every second pixel horizontally on each line). A macropixel contains 2 pixels in 1 u_int32.
Duration : 24mn 52s
Bit rate : 166 Mbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 5:4
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:2
Compression mode : Lossless
Bits/(Pixel*Frame) : 16.000
Time code of first frame : 08:06:40:00 / 08:06:40:00
Time code source : Adobe tc_A / Adobe tc_O
Stream size : 28.8 GiB (98%)
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : 1
Duration : 24mn 52s
Bit rate mode : Constant
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 273 MiB (1%)
Alignment : Aligned on interleaves
Interleave, duration : 1000 ms (25.00 video frames) -
Encoded 3 clips (should have been 32GB instead of 42..)
General
Complete name : E:\My Videos\PrePro\Sequence 01.avi
Format : AVI
File size : 40.6 GiB
Duration : 25mn 59s
Overall bit rate : 224 Mbps
Recorded date : 2015-07-05T10:54+01:00 / 2015-07-05T10:54+01:00
Writing application : Adobe Premiere Pro CS6 (Windows) / Adobe Premiere Pro CS6 (Windows)
Video
Format : YUV
Codec ID : v210
Codec ID/Hint : AJA Video Systems Xena
Duration : 25mn 59s
Bit rate : 221 Mbps
Width : 720 pixels
Height : 576 pixels
Standard : PAL
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 21.333
Time code of first frame : 00:00:00:00 / 00:00:00:00
Stream size : 40.2 GiB (99%)
Audio
Format : PCM
Codec ID : 1
Duration : 25mn 59s
Bit depth : 16 bits
Stream size : 286 MiB (1%)
Interleave, duration : 1000 ms (24.99 video frames) -
Ignoring the differences due to the running time change, the main difference is the video codec used - which is NOT the same as source!
As you can see:
Audio is basically the same. No worries there.
Video source is UYVY-coded, 4:2:2 16bpp or 166Mbps.
Video destination is v210-coded, 4:2:2 21.333bpp or 221Mbps.
This is probably due to Premiere not being able to use the same BMD UYVY codec on output, so tries the nearest available equivalent (the Aja v210 codec) which seems to be not as efficient in its coding. A check on that codec format shows that it does indeed pad to 32bit byte boundaries, thus there is always extra overhead/baggage. Should NOT affect the quality, however.
Interesting that neither source nor destination gives any indication about interlacing.
Scott -
I also just noted that 16bpp in the UYVY is not possible for 10bit 4:2:2 (likely, it's using 8bit). It SHOULD be 20bpp (2/3 of 10bit 4:4:4's 30bpp). So you should double-check to see if you actually are getting your full 10bits encode. Posterization/Banding?
Premiere Pro CS5.5 H.264 1080p file size too huge?
By x2x3x2 in forum Video ConversionReplies: 3Last Post: 21st May 2012, 23:18 -
Exporting HDV with Premiere Pro 2
By HDVth in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 9th Mar 2011, 15:41 -
exporting from premiere: progressive or interlaced ?
By codemaster in forum EditingReplies: 12Last Post: 5th Jan 2011, 01:57 -
adobe premiere CS5 video exporting issue
By bteamstephen in forum Capturing and VCRReplies: 4Last Post: 11th Dec 2010, 01:55 -
quicktime pro will exporting to h.264 solve this huge file size issue?
By cybershot in forum Newbie / General discussionsReplies: 7Last Post: 10th Oct 2010, 22:43
