I have this front-end/batch script generator for ffmpeg h.265 encoding written in ahk. It is nothing special or unique. But I have since forgotten the ahk language and any type of simple coding. I am also struggling with my eyesight. If someone is feeling charitable, can they add batch encoding to this program? You can change the "Created by" line and put your name. Thank you. The source code file extension can be changed to .ahk or .txt and be opened in notepad. The source code file is at the bottom of the post.
program:
64bit
https://drive.google.com/file/d/0B695hmOChptNY3lJU0NGN1pUTDQ/view?usp=sharing
32bit
https://drive.google.com/file/d/0B695hmOChptNMlVIckhMS2x1eWc/view?usp=sharing
Source Code of exe file (exe file only works inside downloaded folder above):
https://drive.google.com/file/d/0B695hmOChptNRVFmVUdXcHBEQ1E/view?usp=sharing
				Results 1 to 1 of 1
  Announcing QtlMovie, a specialized graphical front-end to FFmpegBy lelegard in forum Latest Video NewsReplies: 58Last Post: 9th Apr 2017, 15:33
  Add outro in batch to without re-encodingBy M00nsp3ll in forum Newbie / General discussionsReplies: 1Last Post: 18th Jan 2015, 12:47
  Trim MV4 Files, Front and Back - BatchBy poleary200 in forum EditingReplies: 19Last Post: 12th Dec 2013, 14:29
  Batch method of adding the same clip at the end of a large amount of videosBy rasterboy in forum EditingReplies: 15Last Post: 8th Nov 2012, 04:24
  batch add logo to mkv video?By Pitorasilo in forum EditingReplies: 2Last Post: 3rd Feb 2011, 07:04
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
