VLC has been letting me down lately, so I'm giving PotPlayer a try -- it works nicely so far, except for one thing: I cannot watch ZMBV videos in their original quality.
(ZMBV is a lossless codec, used for instance by emulators such as DOSBox and Altirra.)
Here is a sample video, plus two zoomed-up still shots that clarify the problem:
VLC (top) shows the video as originally recorded.
PotPlayer (bottom) shows a blurry mess w/ poor colors.
I went through every video renderer in PotPlayer, and every colorspace setting; I took an hour or so to explore the menus(!). Nothing helped -- what I'm suspecting now is the decoder.
It almost looks like the chroma is being decoded at a lower resolution than the luma. But why would that happen? Doesn't PotPlayer use ffmpeg decoders, just like VLC does? Can anyone even guess what's happening here?
				Results 1 to 9 of 9
	Can you force the video decoder to output RGB? It's putting out YV12 on your computer. MPCHC plays it properly with the video decoder (LAV) set to RGB.
	Yeah, already tried forcing the output colorspace to RGB (various types thereof). This didn't help - I see now that certain renderers fall back to YUY12 when forced, while others (e.g. VMR 9 Renderless) claim to be showing RGB, but I still get the same visual result.
 Well, thanks for testing. I might experiment with using LAV decoders in PotPlayer then...
	Okay, this is extremely strange: both MPCHC (w/LAV filters) and VLC can play these files fine.
 So I tell PotPlayer to use the LAV Video Decoder, and adjust the output to RGB... nope: still the exact same issue as above. I check the playback info to make sure that the settings were successfully applied. They were, but there's no improvement.
 Too bad - I *like* PotPlayer for being so flexible and configurable... but if all those options are not enough to properly decode my videos, I guess I'll have to go with something else. :(
	It's just a guess, but PotPlayer uses internal intermediate video filter (the audio one as well) - 'Built-in Video Codec/Transform'. It might have unexpected effects - as far as I remember it can increase CPU use by the player for HEVC videos for example. Maybe you should go to Preferences - Filter Control - then to the right side and change 'Built-in Video processing filter settings' conditions , etc.
	@largactyl: actually I'm curious as well - what have you changed to make it work? After writing you about my suspicions I didn't have time to fiddle with the settings and I just tried to add ZMBV, ZIP and YV12 in FourCC for Conditions: Disable with the following conditions. But it doesn't seem to turn 'Built-in Video Codec/Transform' off in this case. What splitter, video decoder etc are you using for your video?
	I'm using the LAV audio decoder, splitter, splitter source, and video decoder (added all four under Filter Control > Filter Priority (Default), and set their Priority to "Prefer"). As for the built-in filters, I just disabled them all; haven't really tried setting FourCC-specific conditions yet.
  Potplayer & Color SpacesBy vdoep86 in forum Software PlayingReplies: 6Last Post: 26th Feb 2015, 07:09
  Uncompressed OR Lossless to Lossy?By raphaelolaguer in forum Newbie / General discussionsReplies: 5Last Post: 24th Feb 2014, 03:50
  Lossy 32 bpp (32-bit color) codecsBy videohelperee in forum Video ConversionReplies: 9Last Post: 12th Dec 2011, 22:13
  Recommendation of Lossy to lossy format(WMV/AVI/MKV to H264) via X264.By xjohn in forum Video ConversionReplies: 6Last Post: 17th May 2011, 23:27
  Media player classic home cinema x64 refuse to play ZMBVBy Blå_Mocka in forum Software PlayingReplies: 0Last Post: 12th Nov 2010, 14:13
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
