I have a source mkv file which plays with no problems, I used mkvextract to extract the audio and video streams. I then remastered the audio stream and encoded that into a DTS file. So I have 2 raw streams to mux. The DTS (raw) file can be played in VLC with no problems.
I then used tsmuxer to containerise these 2 streams into a m2ts file, however there is no audio output.
I tried using mkvmerge to make a mkv file and it plays with no problem.
Have done this thousands of times before with no issue like this, anyone have any ideas?
The DTS file plays as does the the mkv file, both in vlc so thats not it. However, vlc has no option to select an audio track under Audio>Audio Track for the tsmuxer file which does not play audio.
I have determined that the problem is with the h.264 stream as it does not matter what type of audio stream (LPCM, AC3, DTS) I mux with it, there is no sound.
I have uploaded a clip.https://forum.videohelp.com/attachment.php?attachmentid=32381&stc=1&d=1435874331Last edited by shag00; 2nd Jul 2015 at 17:02.
What are the video details then?
Maybe try another m2ts muxer....hmm...maybe can bdrebuilder import the mkv and make a m2ts.
edit: The above clip works fine in VLC. I can select audio track.Last edited by Baldrick; 3rd Jul 2015 at 02:48.
Ooops, sliced a bit off the wrong file. However, to solve the problem I re-transcoded the source and everything works fine. Thanks for your assistance.
MkvТоMp4 v0.224 - rapid tool for repack Mkv to Mp4
By oreons in forum Video ConversionReplies: 808Last Post: 7th Mar 2022, 01:43 -
TSmuxer problem with m2ts Subtitle
By davidecit in forum Authoring (Blu-ray)Replies: 5Last Post: 16th Jun 2013, 19:06 -
Colossus AVCHD TS to MKV Repack Question
By Rick2875 in forum Video ConversionReplies: 1Last Post: 31st Dec 2012, 23:37 -
MKV to M2TS w/ TSMuxer
By averageschmoe in forum Video ConversionReplies: 2Last Post: 22nd May 2011, 00:21 -
tsmuxer help with .mkv to .m2ts for PS3
By sharoo in forum Newbie / General discussionsReplies: 0Last Post: 15th Jan 2011, 12:12
