Hi,
I try to convert a video to an encrypted video using VLC by command:
All are OK and I could play the output video by command:Code:vlc -I dummy input.mkv --sout='#std{access=file, mux=ts{csa-ck=THISISMYKEY,use-key-frames},dst=./output_enc.mkv}' --sout-all --sout-keep vlc://quit
However, the frame rate of output video is 60fps instead of 30fps of original input. I want to keep all input video parameters. What should I do?Code:vlc --ts-csa-ck=THISISMYKEY ./output_enc.mkv
Many thanks!
Results 1 to 1 of 1
How do I encrypt a WMV file?
By Videogamer555 in forum Video ConversionReplies: 7Last Post: 29th Sep 2013, 01:34 -
VLC:How can I add new/outer fitler or decoders to VLC?
By dayangwc in forum Newbie / General discussionsReplies: 2Last Post: 12th Jul 2013, 07:33 -
Problem with video in VLC
By ROBO731 in forum Newbie / General discussionsReplies: 4Last Post: 28th Nov 2012, 16:25 -
Video goes WIDESCREEN After A Few Seconds In VLC
By hech54 in forum EditingReplies: 5Last Post: 28th Jun 2012, 11:41 -
VLC Loop Video
By pepegot1 in forum Software PlayingReplies: 3Last Post: 19th Oct 2010, 02:32
