Hi guys! Hope you can help me with this one.
I need to convert a mov to mp4 with this settings.
How can I do this? What is the best software for this?
VIDEO:
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
Overall bit rate mode : Constant
Overall bit rate : 6 179 Kbps
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : No
Format settings, ReFrames : 3 frames
Codec ID : avc1
Bit rate mode : Constant
Bit rate : 6 000 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.058
Stream size : ... (98%)
Language : English
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
AUDIO:
Format : AC-3
Format/Info : Audio Coding 3
Format settings, Endianness : Big
Codec ID : ac-3
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : ... (2%)
Language : English
x264VFW: settings to achieve "same" original quality
By marcorocchini in forum Newbie / General discussionsReplies: 7Last Post: 5th Sep 2014, 17:41 -
How to achieve this kind of reverb?
By Mephesto in forum AudioReplies: 9Last Post: 6th May 2014, 23:18 -
miniDV to ??? to achieve best possible quality?
By nemo2002 in forum Video ConversionReplies: 5Last Post: 28th Jan 2013, 23:26 -
Achieve the best possible audio quality.
By Robertiebert in forum Video ConversionReplies: 8Last Post: 23rd May 2011, 09:35 -
How do i achieve this effect in FCP 5 ?
By d.ennion in forum EditingReplies: 2Last Post: 24th Jul 2010, 21:13
