I know my install of VD has worked with AVIsynth files in teh past .......... but I can't seem to get anywhere now.
So stepped back to beginning ... went to the beginners intro http://avisynth.nl/index.php/First_script
created the simple one line script ... and while it will open and run correctly in WMP
When I try open up VD and then File>open video file and point it to the test.avs (or any .avs) I get the error 'unable to open file'
So frustrating that I can't get this first tsep running - am I missing something ?
Found one source on-line that states that I need to use VirtualDubMod ... but never used that before.
VirtualDub should work. Someone else might be able to suggest why it won't open scripts, but I'd try VirtualDubMod anyway just to see if it will.
How are you opening the script?...Do NOT use "Run Script"! Use only "Open Video File". Many people get stuck on that one.
Scott -
That is what I am using.
It will open mp4 and avi OK, but fails on all .avs files. -
Then it appears something isn't installed correctly. (32bit/64bit mismatch?)
Scott -
This is strange as it was all working .... I'll try re-install (its all 32 bit)
avisynth - How to write avisynth script for rgba overlay
By moelover in forum EditingReplies: 3Last Post: 13th Apr 2014, 12:24 -
How can i Use VDub Script[.vcf] into Avisynth Script[.avs] ( Megui )
By Maskoff in forum EditingReplies: 1Last Post: 25th Jun 2013, 15:30 -
avisynth script
By mmbwdpnz in forum Newbie / General discussionsReplies: 6Last Post: 24th Feb 2013, 00:01 -
Opening a .MOV in AVISynth
By sphinx99 in forum Video ConversionReplies: 4Last Post: 17th Aug 2011, 08:06 -
Need Help with My AviSynth Script
By Enkidu in forum Newbie / General discussionsReplies: 3Last Post: 21st Jan 2011, 21:37
