Howdy,
What is the highest quality DVD to VCD converter you know?!
Cheers.
All the good ones that used to work best for VCD do not work in W7-64.
Use a VM or dual-boot to WinXP-SP2-32, and use TMPGEnc Encoder (MPEG1/VCD settings) and VCDEasy (if you can still find it). I wouldn't use SP3 with VCDEasy, because it seemed to break for some people at that point.
Or explain why you THINK you need VCD in this day and age, when many people consider even DVD or BD to be passe. Could be you have many better, more modern alternatives.
Scott -
"Quality" and VCD in the same sentence?
Google is your Friend
VCD to DVD not finalized from start.
By Flattop1423 in forum Newbie / General discussionsReplies: 5Last Post: 29th Mar 2014, 15:52 -
What is the best DVD Authuring Program for VCD to DVD?
By Rexkh in forum Authoring (DVD)Replies: 14Last Post: 16th Nov 2013, 20:21 -
Rip DVD and VCD to PC
By peebee23 in forum DVD RippingReplies: 6Last Post: 8th Jul 2013, 23:47 -
vcd on dvd
By jamespoo in forum Authoring (VCD/SVCD)Replies: 13Last Post: 20th Feb 2013, 05:01 -
How do I fit a DVD on one VCD with DVDx 4.0?
By Xoanon in forum DVD RippingReplies: 5Last Post: 27th Apr 2012, 03:20
