Alt+X won't exit the program as it's supposed to. All it does is open and close the Start screen. I have Windows 8.1.
Latest version?
What happens if you use alt-f4?
Alt-x works fine in win 7 here. -
That's great. Alt+F4 worked. Thanks. I'm just confused as to why Alt+X stopped working. And yes, latest version. It's very odd. When I started using the latest version, Alt+X worked fine. Only now is it opening up the Start screen instead. I thought, however, that it might just be a bug with the latest version, so I uninstalled and installed an older version from 3 months back. Didn't help. Alt+X still opens the Start screen. I think it might have to do with my keyboard, or maybe my screwed up hard drive. I need to know though so I don't recreate the problem when I install my new hard drive. Every other keyboard shortcut is working fine, by the way, and the keyboard in general seems to be fine otherwise. It's just that Alt+X is the default keyboard shortcut for closing MPC and it used to work fine and now all of a sudden it just opens and closes the Start screen.
SOLVED!
Alt+X is now back to exiting MPC as it should. There was no hardware or software glitch. It suddenly occurred to me that, because I'd installed Start Menu 8, and my Windows key now brought up the Start menu instead of the Start screen, that Start Menu 8 might also be the reason why Alt+X had taken on another function. Sure enough, when I uninstalled Start Menu 8 to test that theory, and opened up MPC, Alt+X closed it just as it should have. Gonna reinstall Start Menu 8 though because I want to keep it, so from now on, when I want to exit MPC, I'll use Alt+F4
Weird problem with Media Player Classic Home Cinema
By Bruce Wayne in forum Software PlayingReplies: 14Last Post: 29th Jan 2016, 13:53 -
media Player Classic Home Cinema loses sound
By nadz in forum AudioReplies: 1Last Post: 8th Oct 2013, 23:12 -
A question about Media Player Classic Home Cinema
By infini in forum Software PlayingReplies: 10Last Post: 20th Sep 2013, 07:33 -
Media Player Classic Home cinema dubdelay
By web_maven in forum Software PlayingReplies: 2Last Post: 17th Mar 2012, 07:01 -
Media Player Classic - Home Cinema Settings Help
By ACiDxCHRiST in forum Newbie / General discussionsReplies: 5Last Post: 18th Sep 2011, 00:29
