  1. Hello,
    I need some help.
    I wont to play 3D Blu-ray disk with MPC-HC. Furst, I mount it, but when i play it with MPC-HC , I can watch only 2D. Is there some options to watch 3D Blu-ray with MPC-HC? I try to watch this mouvie "Our Universe 3D -BLUEBIRD.iso" .
    Feb 2014
    QUÉBEC
    No, You need powerdvd , arcsoft total media theater or Stereoscopic player .
    You also need 3DTV play if you have nvidia hardware.
  3. Тhanks for the reply,
    but I have another problem, I can instal noting on my PC, becouse I not administrations rights. I have only MPC-HC and Windows Media Player. Is there any solution to watch 3D Blu-ray with these two players?
  4. Member Cornucopia's Avatar
    No. Use "Run As" to run/install as admin.
    Feb 2014
    QUÉBEC
    from a 3D iso or a folder, no.
    But you can encode your movie to SideBySide (SBS) (quality loss) and it will work with mpc-hc.
    But you also need to install other software like Bd-rebuilder or dvdfab to achieve this.
  6. Originally Posted by Cornucopia View Post
    , Our sistems administration wil be very angry, if i do that. I have to buy my own PC.
    Тhank you people for all answers.
