I've long been able to use Pot Player's CTRL+F5 and CTRL+F6 keys to toggle through aspect ratios of vids playing in full screen mode — until now.
Regardless of how I select "Playback/Aspect Ratio/AR" and "Playback/Aspect Ratio/Override AR" options, the player changes these settings, on its own, after my choices have been applied and OK'd. It's a mystery.
Choosing "Cycle Aspect Ratios" by right-clicking the screen allows CTRL+F5 and CTRL+F6 toggles to function, but only in player sizes smaller than full screen. When I access this menu again, I see that "Keep Aspect Ratio (Recommended)" has changed to one of the two stretch settings while "Cycle Aspect Ratios" becomes 2.35:1 at times, Custom (4:3) at others.
My MO is to drag video files of varying dimensions from my secondary monitor into a full-screen Pot Player on my primary. I simply want to adjust a new video's AR using only the F+5 and F+6 function keys — without the bother of having to downsize, then full-screen the player to do so. This once worked splendidly. That was then.
I'm running 32-bit PotPlayer 1.6.54549 under 64-bit Windows 8.1 with an Intel i7-3770 CPU and NVIDIA GeForce GTX 750. MP4s play through NVIDIA's CUDA decoder. Here are my Aspect Ratio preferences . . .
Playback | Playback Settings
Default window size: Do not use
Default window aspect ratio: Do not use (Recommended)
Playback | Aspect Ratio
AR Mode: Keep Aspect Ratio (Recommended)
Override AR: Default Original DAR [this refuses to stick]
☐ Adjust AR to Window Size
☐ Enable the Selected Aspect Ratio Mode when the margin...
☐ Provide the specified ares...
Any suggestions? Thanks in advance!
	 Michael Linder Michael Linder
 Currently facing Media Crimes charges
  Pot Player Blu-Ray Time-On-Screen in Full-ScreenBy robertkjr3d in forum Software PlayingReplies: 2Last Post: 31st Oct 2014, 05:46
  PotPlayer - How to unhide pause/play menu on mouse movement in full screen?By tahayassen in forum Software PlayingReplies: 3Last Post: 30th Jan 2014, 22:02
  Full Screen Ripped DVD is not Displaying Full Screen on Widescreen TVBy jgciamarra in forum DVD RippingReplies: 3Last Post: 23rd Jan 2012, 18:42
  Windows Media Player 8 full screen DVD playback not full screenBy brassplyer in forum Software PlayingReplies: 1Last Post: 3rd Jan 2012, 16:43
  How to Maintain Correct Aspect Ratio in PotPlayer with Full ScreenBy drstew12 in forum Software PlayingReplies: 1Last Post: 20th Dec 2011, 20:25
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
