Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
Closed Thread
    Jan 2014
    Somewhere
    hello guys,
    I have a serious problem with ffmpeg (zeranoe build latest version).
    Basically even if I use a command line like that one:
    ffmpeg.exe -hwaccel auto -y -i testinput.mkv -map 0:v:0 -c:v libx265 -crf 20.0 -preset veryslow -x265-params level=0:profile=undefined:pmode:no-pme:no-high-tier:ref=6:bframes=6:open-gop:keyint=250:min-keyint=25:b-adapt=2:bframe-bias=0:rc-lookahead=40:no-scenecut:b-pyramid:me=umh:subme=4:merange=57:temporal-mvp:weightp:no-weightb:max-merge=2:no-weightb:no-rect:no-amp:vbv-bufsize=0:vbv-maxrate=0:vbv-init=0.9:no-strict-cbr:qcomp=0.8:qstep=4:aq-mode=1:aq-strength=2:cutree:no-early-skip:min-cu-size=8:ctu=64:no-fast-cfb:ipratio=1.4:pbratio=1.3:cbqpoffs=0:crqpoffs=0:rd=3:psy-rd=0.5:psy-rdoq=1:no-b-intra:no-fast-intra:rdoq-level=2:no-tskip:no-tskip-fast:cu-lossless:tu-intra-depth=3:tu-inter-depth=3:strong-intra-smoothing:no-constrained-intra:nr-intra=0:nr-inter=0:qblur=0.5:cplxblur=20:signhide:sar=16 outputwaddawawd.mkv
    only the preset option are applied to the encoder, while all other -x265-params are ignored and ffmpeg warn me saying that:
    [libx265 @ 0000000005c324c0] Unknown option: profile.
    [libx265 @ 0000000005c324c0] Unknown option: pmode:no-pme:no-high-tier:ref.
    [libx265 @ 0000000005c324c0] Unknown option: open-gop:keyint.
    [libx265 @ 0000000005c324c0] Unknown option: no-scenecut:b-pyramid:me.
    [libx265 @ 0000000005c324c0] Unknown option: temporal-mvp:weightp:no-weightb:max-merge.
    [libx265 @ 0000000005c324c0] Unknown option: no-weightb:no-rect:no-amp:vbv-bufsize.
    [libx265 @ 0000000005c324c0] Unknown option: no-strict-cbr:qcomp.
    [libx265 @ 0000000005c324c0] Unknown option: qstep.
    [libx265 @ 0000000005c324c0] Unknown option: cutree:no-early-skip:min-cu-size.
    [libx265 @ 0000000005c324c0] Unknown option: no-fast-cfb:ipratio.
    [libx265 @ 0000000005c324c0] Unknown option: no-b-intra:no-fast-intra:rdoq-level.
    [libx265 @ 0000000005c324c0] Unknown option: no-tskip:no-tskip-fast:cu-lossless:tu-intra-depth.
    [libx265 @ 0000000005c324c0] Unknown option: strong-intra-smoothing:no-constrained-intra:nr-intra.
    [libx265 @ 0000000005c324c0] Unknown option: signhide:sar.
    This happens even if I do not declare preset options (in this case the encoder is set with the default options of the "medium" profile).
    As I know even if I declare a preset and other parameters the preset options are overwrited with the new params I declare. So I cannot understand what's the problem.. maybe a syntax problem or what? by the way the encode works fine.
    Thanks in advance!
    canada
    Please do not cross post,one thread is enough,this thread is closed.Please continue in your other thread.
    https://forum.videohelp.com/threads/372625-ffmpeg-does-not-apply-parameters-with-libx265
