Hay
I have a bunch of ISO blu ray 3d films and I want to watch it throught externall HDD on PS3......I dont know what to do?
Is possible to split a 30 and more GB file into FAT32 disk?
Do you own a 'Smart' tv? If so, try streaming them from PC. Or to the console.
Visit: http://serviio.org/ -
No. It is not possible with your scenario. BD ISOs aren't just a bunch of miscellaneous files: as disc images of an authored format, they have a specific, clearly defined structure and ordering. Messing around with that (because of some arbitrary size limitation), destroys playability (especially in the case of 3d). Not only that, but FAT32 isn't a supported filesystem for most all authored disc formats: AudioCD, S/VCDs, DVD-Videos, DVD-Audios, SACDs,, BDs, 3DBDs, or UltraHD BDs.
Choices:
Mount the ISOs on an HTPC (with a 3D player app) and play them directly out HDMI 1.4 to your 3DTV (bypassing the PS3).
Burn the ISOs to backup 3D BD-R/Es and just play them as discs in the PS3.
Extract the 3D video file assets from the ISO and use them as-is but contained in a more common container and use in an MVC-capable stereo player such as Stereoscopic Player, or convert to a more standard, frame-compatible 3D format and play in many players (possibly including the PS3 with proper layout, encoding & container).
Scott -
@transp - yes I have a smartTv
@cornucopia - the first method I try and working properly....I mount image on laptop and connect it via HDMI 1.4 with PowerDVD and all working great in 3D.....but laptop is not mine and I only try this Solution
Second method with burning ISO is not possible cause I have a dead Blu ray optical disc in the ps3.....
And third method I dont understand fully....you say with extracting files and convert it to a more standard (you mean convert to SBS or h-SBS)?Last edited by Dexy88; 28th Jun 2015 at 20:43.
Yes. (Understand you will lose some quality this way).
blu ray iso to blu ray format
By minititan in forum Newbie / General discussionsReplies: 10Last Post: 30th Mar 2013, 15:49 -
Create a 3D Blu-ra ISO from Folder on HDD
By danswano in forum Blu-ray RippingReplies: 10Last Post: 14th Mar 2013, 21:48 -
DVDFab HD Decrypter : Is DVD to HDD and Blu-ray to HDD decryption FREE?
By Bonie81 in forum DVD RippingReplies: 2Last Post: 8th Jun 2011, 15:28 -
Blu ray iso
By Markfish in forum Blu-ray RippingReplies: 1Last Post: 27th Feb 2011, 18:57 -
blu ray hdd- external hdd
By jayjay97 in forum Authoring (Blu-ray)Replies: 2Last Post: 25th Sep 2010, 01:35
