Results 1 to 9 of 9
  1. This is really got me scratching my head. I am trying to frameserve FHD 29.97p video out of PPro via DMFS and YUY2 to x264 using the following code:
    AVS script:
    AVISource("D:\signpost.avi", audio=false).AssumeFPS(30000,1001)
    x264 script:
    x264.exe --preset slow --level 4.1 --ref 4 --tune grain --crf 17 --vbv-maxrate 40000 --vbv-bufsize 40000 -o "video.264" "signpost.avs"
    When I re-import the video.264 back into PP, PP tells me the PAR is 0.75. When I try playing it back using MPC, it is a mess. Any ideas what is going on?
    If it helps, this is the mediainfo of the source clip which I generated as a lossless AVI export from AE.
    General
    Complete name                            : D:\TestFHD.avi
    Format                                   : AVI
    Format/Info                              : Audio Video Interleave
    Format profile                           : OpenDML
    File size                                : 1.31 GiB
    Duration                                 : 15s 48ms
    Overall bit rate                         : 746 Mbps
    Writing application                      : Lavf56.1.100
    Video
    Format                                   : YUV
    Codec ID                                 : I420
    Codec ID/Info                            : 8 bit Y plane followed by 8 bit 2x2 subsampled U and V planes.
    Duration                                 : 15s 48ms
    Bit rate                                 : 744 Mbps
    Width                                    : 1 920 pixels
    Height                                   : 1 080 pixels
    Frame rate                               : 29.970 fps
    Compression mode                         : Lossless
    Bits/(Pixel*Frame)                       : 11.974
    Stream size                              : 1.30 GiB (100%)
    EDIT: I should add that this was working flawlessly for me before. But now it is like something has infected my system. So I have fallen back to using AME for now. This has really got me down
  2. add --sar 1:1 to the commandline
  3. Thanks pdr, that seems to have fixed the PAR showing up as 0.75 in PPro. But now the video has ugly, blocky artifacts. Here is a quick crop of what I am seeing. Look at those ugly blocky artifacts! The dark pillar down the middle is supposed to look like the right edge of the crop with just a little more shadow. Not even close to that dark. I just don't get it, yesterday everything was fine, now all the sudden nothing works. Thanks so much for the help.
  4. Nothing jumps out at me as the culprit from the screenshot
    Try putting the elementary stream into a container, then importing it. e.g. MP4 or TS . Importing .264 (or any elementary stream) can sometimes cause corruption (in the preview) in various editors . You typically import elementary streams for authoring programs, not editing programs
    Once you put it into container, check with other programs to see if it's only premiere affected. E.g. play it in mpchc or vlc etc...
    And post the mediainfo report for the encode
  5. This is really got me scratching my head. I am trying to frameserve FHD 29.97p video out of PPro via DMFS and YUY2 to x264 using the following code:
    AVS script:
    Also, if you frameserved YUY2, did you forget to put ConvertToYV12() in the script ? Or --input-csp , --output-csp commands ?
    (It is possible to use 4:2:2 AVC in premiere, but only specific variants like AVC-Intra)
  6. It doesn't play well in MPC so it unfortunately isn't just PP that is messing up. Here is the mediainfo of the encoded file. As I have tried to think back through what may have changed, I recalled that I installed a multi-threaded version of AVIsynth, the one that is recommended for running QTGMC MT. I wonder if my version of AVIsynth could be the culprit?
    General
    Complete name                            : D:\video.264
    File size                                : 24.6 MiB
    Duration                                 : 2s 202ms
    Overall bit rate                         : 93.8 Mbps
    Video
    Format profile                           : High@L4.1
    Format settings, ReFrames                : 4 frames
    Duration                                 : 2s 202ms
    Bit rate                                 : 93.8 Mbps
    Bits/(Pixel*Frame)                       : 1.509
    Stream size                              : 24.6 MiB (100%)
    Writing library                          : x264 core 146 r2538 121396c
    Encoding settings                        : cabac=1 / ref=4 / deblock=1:-2:-2 /
    analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.25 /
    mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 /
    cqm=0 / deadzone=6,6 / fast_pskip=1 / chroma_qp_offset=-4 /
    threads=12 / lookahead_threads=2 / sliced_threads=0 /
    nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 /
    bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 /
    open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 /
    intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=17.0 / qcomp=0.80 /
    qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=40000 / vbv_bufsize=40000 /
    crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.10 / aq=1:0.50
  7. Originally Posted by poisondeathray View Post
    I tried adding ConvertToYV12() and sadly doesn't make any difference.
  8. Did you put video.264 into a container ? MPCHC can have problems playing elementary streams too...
    If you preview the .avs for the signpost, in something like vdub or avspmod - can you see the artifacts ? If you can't - then it's unlikely anything is wrong with avisynth or anything upstream of that
  9. Originally Posted by poisondeathray View Post
    Wow, after fully following your advice and putting the audio and video into an MP4 container using MP4Box, none of the problems are there. So I guess I was panicking over nothing. Very strange cuz MPC seemed to play elementary streams fine before.
