This post is based on my experiences using "How to convert to SVCD the FOOLPROOF way with Cinema Craft Encoder, including how to resize" guide, based on this website
This guide is exclusively about using CCE and VDUB1.4.9 for frameserving as the above guide suggests.
I do not endorse or condone the use of either of these software programs.
These are four hard learned lessons that I thought I would share with everyone based on my hardships in converting from Divx to MPEG2 compliant
I am sure there are more, so feel free write your own guide if this doesn't apply to you.
1. Cinema Craft Encoder (CCE)2.62 and above usually does not allow VDUB to frameserve it directly. "How to convert to SVCD the FOOLPROOF way with Cinema Craft Encoder, including how to resize." guide tells you that you can, it may or may not be referring to CCE 2.5
I originally tried with VDUB1.49 and CCE 2.62.
Problem: CCE 2.6x gives you an error something to the effect that "The VDR file that you choose is not recognized as an AVI file."
Solution: Downgrade to CCE 2.5. On my computer, it successfully recognizes the VDR file (VDUB Frameserving file extension) to be recognized as a valid AVI file.
2 CCE 2.5 may or may not require that in VDUB you have included an audio file in your frameserver. You then uncheck audio in CCE and it may or may not work fine.
Problem: Avi File Openf:\Your file) Unknown Error
Solution:
*JJamez Certifiable Joined: 09 May 2001 Posts: 219CCE needs audio input or else it produces an error or just crashes in my case. In VDub, under Audio, select WAV source and choose any old wav you have handy, doesn't matter what size. Then when you frameserve, CCE should have no problems - then uncheck the Audio file in the CCE project settings.
The audio may make all of the difference, depending on your computer's configuration Like JJAmez says above, it doesn't matter what wav file you use, just as long as CCE sees audio on the frameserver.
3.Depending on the AVI file that you are working from, CCE may or may not require the frameserver to have outputted an "old format avi"when stripping the streaming video from your DIVX file.
Problem:"Read only 0 Bytes, while expecting 8 bytes " error.
Solution:
* revjake Member Joined: 25 Mar 2002 Posts: 25Open up your original divx .avi file in Vdub. Turn off the audio, and make sure that video is set to "direct stream copy."
Then, head to the file menu and save your now-soundless .avi using "save old format .avi."
Take the (new) old format .avi you just saved, and CCE will love it
4. CCE 2.5 has been known to, in some configurations, not run unless it is in compatibilty mode in Win2k/XP Pro. Should you get an error message, and none of the other solutions listed here or elsewhere seem to solve your problem, you may want to try this:
In XP, right click on properties, choose the compatibility mode tab and then choose win95, or WinNTSP5. May or may not work like a charm. In 2000 you need to run apcompat.exe, which may or may not be found in the support folder on your WIn2k CD. Choose WInNT sp5 compatiblity and it may or may not be self explanatory from there. I actually looked up apcompat.exe on www.microsoft.com, and it had complete instructions.
Regards,
Corky
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
the sulotio to Problem:"Read only 0 Bytes, while expecting 8 bytes " error.
works
but how can i add the audio back -
I'm trying to follow the SVCD creation guide at
http://stanwebber.dirtyhosting.com/dvd.html
but when I try to open my .vdr file from VirtualDub in Cinema Craft
Encoder SP 2.5 I get this error message from CinemaCraft:
AVIFileOpen("C\...\bmu.vdr"): According to the registry, the type of file specified in AVIFileOpen does not have a handler to process it.
TMPenc also has an error saying that it is not a valid avi file.
Has anyone else had this problem? I'm thinking of trying it on a win2k machine, instead of this XP box.
Cerote. -
good guides but just a note that you CAN frame serve to CCE 2.64.10 (now) and the audio has been improved -- though still not great , compatability w/ win2k is perfect .. dont know about XP...
seems slower now though ...
Difficult to read disks...HW or SW change more helpful?
By Golem in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2008, 00:41 -
5 Helpful Tips When Shooting Video
By GabeJacobs in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 26th Jul 2008, 23:18 -
By GabeJacobs in forum Off topicReplies: 1Last Post: 4th Jul 2008, 01:11 -
Vdub frame serving to CCE ?, UPDATE ..Fixed the Error
By theewizard in forum Video ConversionReplies: 15Last Post: 31st Jan 2008, 23:24 -
Updated TMPGEnc
By avz10 in forum ComputerReplies: 4Last Post: 24th Jun 2007, 13:20
