Issue #1 - I have a decrypted DVD with audio commentary option; when I rip it with DVD-SHRINK (full disc or reauthor) I uncheck the audio commentary box, but the ripped VOB's still have that voice over - how do I get rid of it?
Issue #2 - I have video files with english subs in a separate folder, but not in .SRT (only as .SUB) - neither Handbrake nor Xmedia Recode will import SRT subs - any ideas?
Thanks to all!
#1 - What did you decrypt it with? Maybe not all the protection was removed and you have a 'crossed stream' situation.
#2 - https://forum.videohelp.com/threads/167667-Convert-sub-idx-to-srt-subtitles then I use XviD4PSP to burn them in. -
DVDShrink and DVD Decrypter did their job. I opened the new files with Handbrake and it gave me the audio option to select only the english track w/o commentary. The first trick being to decrypt as full disc, not re-authored.
Still working on the subtitles issue - can't find a program that will load .SUB files (although Handbrake accepts .SRT)
Thanks for the advice! -
DVDShrink and DVD Decrypter did A job. They are both over 10 years old and have never been updated since 2004/2005.
Try a modern decrypter and see if it makes a difference: http://sharewareonsale.com/s/winx-dvd-ripper-platinum-freebie-sale.
DVD SHRINK How to remove audio commentary when burning?
By Criswell in forum DVD RippingReplies: 1Last Post: 27th Jun 2015, 21:03 -
Use DVD Fab to capture audio commentary rather than straight film dialog
By loninappleton in forum Newbie / General discussionsReplies: 12Last Post: 20th Aug 2011, 11:26 -
Remove & replace existing audio file in movie
By silvershadow68 in forum MacReplies: 4Last Post: 13th Sep 2010, 09:44 -
MPEG Streamclip:DVD is ripped with commentary audio stream
By camilla89 in forum DVD RippingReplies: 0Last Post: 29th Aug 2010, 09:43 -
tsMuxeR remove directors commentary 2012 for PS3
By xrsixturbo in forum Blu-ray RippingReplies: 3Last Post: 22nd Jul 2010, 20:55
