Hello, I have multiple Anime seasons (Usually 12 episodes) in MKV, and I want to convert them to MP4 with burned in subtitles. How can I do this in batch?
Results 1 to 13 of 13
Nope. I can't see how to auto burn in subtitles in vidcoder batch.
Depending on the subtitle format you can do this with FFmpeg + FFQueue. Create a preset in FFQueue that suits your needs with subtitle burn-in and audio/video encoding and either drag&drop the MKV's to the queue list og click the Batch button and select the files. Select the preset and the stream-types to include and create the jobs + start the queue. FFQueue will btw. detect external subtitles if they have the same name at the MKV's and has an extension that is supported by FFmpeg (or added to the list of extensions in the options dialog). Should be fairly easy to do
I'm the developer behind FFQueue. My posts might reflect this! ;-) -
How to easily burn in/hardcode srt subtitles to mp4/mkv with VidCoder
By Baldrick in forum User guidesReplies: 65Last Post: 25th Jun 2024, 02:11 -
Mux Batch convert MKV to MP4 with subtitles in Linux
By coquex in forum Video ConversionReplies: 7Last Post: 17th Jun 2016, 17:47 -
How to convert any video to AVI or MP4 or MKV with burned in subtitles
By Baldrick in forum User guidesReplies: 42Last Post: 19th Nov 2015, 05:41 -
how do I convert a mkv from VC-1 to something that vidcoder can output
By BirdDaddie in forum Video ConversionReplies: 2Last Post: 18th Dec 2014, 08:52 -
Convert MKV with .ass subs to mp4 with ffmpeg
By bearnado in forum Video ConversionReplies: 2Last Post: 1st Mar 2012, 02:21
