I have a DVD movie that is region 2 and I want to copy it so I can watch it on my region 1 DVD player. How can I do this ? I have a windows 8 pc.
You most likely still won't be able to watch the PAL/Region 2 DVD on your NTSC television.
There are two hurdles you must cross....region codes and video format(PAL vs. NTSC). -
Most DVD rippers will remove the region coding like anydvd, clonedvd, dvdfab, dvdfab decrypter. Burn on a dvdrw/dvdr and test and see if your system supports PAL.
What make and model DVD player do you have? I could try to find the manual and see if it will convert from PAL to NTSC, allowing you to play the disc if the region code is removed. Otherwise, you would have to re-encode the video and author a new DVD with different menus.
If you have an LCD TV, it is often possible to use the TV as a PC monitor and play the DVD with a software player like MPC-HC or VLC that doesn't care about region codes. -
Your PC DVD Player should be able to play several different Region DVD's. You can always use that and watch it on your computer in a media player.
Japan is Region 2 and NTSC. So, if it's a DVD from Japan then making it all-region will allow it to play on any US DVD player. A European DVD, yes, that's a no-go for most US standalone DVD players and TVs even if it is all-region.
If it's for playing on the PC then it doesn't much matter if you're willing to give up one of the 5 region changes you're allowed, or if you make it all-region during decryption.
What's The Best Software To Copy Blu-ray (Region A) To Blu-ray (Region Free
By Arthur_Ballsack in forum Authoring (Blu-ray)Replies: 17Last Post: 25th Jun 2015, 16:02 -
Decrypting Region 2 DVD on Region 1 Drive
By pone44 in forum Video ConversionReplies: 18Last Post: 14th Mar 2015, 08:42 -
Help with playing region 1 DVD's on region 2 player
By jenirwin1974 in forum DVD RippingReplies: 4Last Post: 22nd Apr 2012, 11:20 -
Region 1 Samsung dvd-vr375 to switch to region free
By catleo in forum DVD & Blu-ray PlayersReplies: 3Last Post: 27th Dec 2011, 10:25 -
Euroline DVD100 DVD Player Region all region code/hack?
By mjgjhb in forum Newbie / General discussionsReplies: 0Last Post: 21st Jul 2011, 09:26
