Results 1 to 30 of 33
  1. Help! I keep getting malware and even after I uninstall it from "UNINSTALL a PROGRAM" under the Control Panel, random programs keep coming back after I restart my Win7 computer. These annoying popup adds won't go away!!!!! It's like they come back under a different name.
    I also use the following programs, run full scan and remove but it keeps randomly coming back with different program names.
    I use these: CCleaner, Malwarebytes AntiMalware, SUPERAntispyware, AdwCleaner and Hitman Pro.
    I just went to Uninstall a program and I see installed on 6/27 (I didn't install these and have no recollection of it being installed)
    1) MaxComputerCleaner Maintenance
    2) Microsoft Visual C++ 2013 Redistributable (x86)
    3) Solid YouTube Downloader and Converter 6.2.0.1
    4) NinjaLoader
    5) KNCTR
    6) Infonaut 1.10.0.14
    I also go to Tools --> Extensions --> in my Chrome and Firefox browser to delete anything that looks funky, but its not getting rid of everything completely. Am I missing something?
    Help!
    Feb 2004
    Australia
    The root cause is Infonaut
    Infonaut removal guide
  3. I even did a MSCONFIG and go to "startup" tab. I disabled this funky item called itibiti.exe. It was the KNCTR that I removed from the control panel. It says the location C:Program Files (x86)/Itibiti Soft Phone/itibit.exe
    However, when I go to that folder on my C drive, I cannot even find it. I deleted it from the Uninstall Program in the Control Panel, but why is it showing up in the "Startup" tab in MSCONFIG?
    I am guessing this is the malware that is causing it to install all these other strange programs like NinjaLoader and MAxComputerCleaner Maintenance and Infonaut 1.10.0.14
  4. Originally Posted by Bjs View Post
    I ran Rkill and it couldn't find any malware service to stop or malware processes to kill.
    I already ran Malwarebytes 2.1.6.1022 (trial version) also.
  5. Isn't Infonaut a malware, not a virus? I ran Microsoft Security Essential and nothing is found.
  6. Antivirus can find malware also
    Not all antiviruses equal on finding
  7. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Dont forget HiJackThis:
    http://download.cnet.com/Trend-Micro-HijackThis/3000-8022_4-10227353.html
    and hijackthis.de (analyzer)
  8. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    For Windows 7 x86 or X64, just run COMBOFIX.
    Link: http://www.bleepingcomputer.com/download/combofix/
    1 - Restart in safe mode/security mode (F8 at power button to select this before start Windows)
    2 - Disable any antivirus.
    3 - Run it and enjoy.
    Sometimes, run twice.
    Claudio
  9. Banned
    Oct 2014
    Northern California
    My general suggestion is that if a system is infected or compromised to restore a system(image) backup.
  10. Thanks all.
    I already ran all these programs. I don't understand why itibiti.exe (KNCTR) is still found under my "startup" tab under Msconfig? Why is it still there?
    I unchecked it. But why does it still show up?
  11. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Run MalwareBytes (or your favorite malware tool) from Safe Mode.
    It could still be listed in the Registry even if it's uninstalled. Just because you see it listed in MSConfig does not mean it's still present and/or running. Manually remove it from the registry.
    Google is your Friend
  12. Originally Posted by jyeh74 View Post
    Some times when you accidentally disable important startup program
    and you want start run again
    So on Msconfig use fail safe, its disable program from running
    but not remove from the list
    In others programs you have option to remove from list:
  13. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    If use CCLEANER (any version), try this:
    Claudio
  14. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    "disable" only leaves them set to not run. "delete" would remove them from the start up list.
    Feb 2004
    Australia
    The problem tends to be two side.
    1: Removal by any means to succeed ... 50/50
    2: Removal by adhering to a set of rules and applications in a particular order to succeed
    Your in 2 ... Where some applications will fail to detect due to other scanners removing key elements already.
    Hopefully you kept logs and notes to identify problematic files.
    Anyone who tell's you to turn of your av shield should be avoided
    If the av product has be compromised then do not waste time ... backup files and either reload a system backup image or reinstall the os again.
    1: Enter safe mode
    2: Head to users account folder in windows explorer
    3: Enable hidden files and folders to display
    4: Head into users application data folder
    5: Check for remnants here of the offend application by folder / file name and remove them
    6: Clear out all temp folder ... temporary internet files, etc.
    7: Repeat this search under "program files" and remove folders and contents of these folders if found
    8: Clean out windows/temp and windows/precache (only a few files should remain in temp as these are being currently used by the system)
    9: Run regedit and search for remnants and delete them
    This guide includes info on where startup items are found in registry and under startup programs group
    10: Suggest you now make a system backup image pre disabling system restore
    Reboot ... if no more popups etc then success
    If not then
    1: Restore system image, or
    2: Backup user files and perform clean os reinstall
    Combofix should only be used under guidance ... not for the inexperienced.
  16. At this point I would just do a clean install.
  17. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Once again, try COMBOFIX. Its a 3 clicks only.
    Claudio
  18. Originally Posted by newpball View Post
    Yeah. But something tells me the OP has neglected to provide himself with that option.
    The first time you get a really screwed system, man you'll be glad you made a system image. Better than fighting to clean it up and maybe having to do a clean install anyway. Even if you only image once, after install, updates and program install/configuration.
    Pull! Bang! Darn!
  19. Originally Posted by fritzi93 View Post
    Not the most system savvy person so not sure how to backup everything and do an image and completely reinstall everything. If can clean out, then its easier. I haven't run the Malwarebytes in safe mode, only in normal mode.
  20. Well, I hope you're able to fix it. Follow the suggestions already given
    Once you've squared things away, either by killing the malware or a clean install, think seriously about making a backup image.
    It doesn't help you at this moment, but imaging your OS drive is very easy.
    Get the free version of Acronis available from Seagate or WD.
    All you need is a drive in or attached to your computer from one of those two makers and the matching version of Acronis.
    And of course a separate drive from the OS with enough space for the image. From within Acronis, you make a rescue CD to boot from.
    Imaging takes a few clicks and then 10 minutes or so, depending. Restore takes about the same time.
    Good luck.
    Pull! Bang! Darn!
  21. Member WazaKrash's Avatar
    Jan 2015
    in Europe
    Strange, normally MalwaresBytes or Adwcleaner should help you to eradicate all malwares
    To uninstall completely something and be sure that no component doesn't stay on your computer, you can use Revo Uninstaller.
  22. Revo could not find it.
    Arg....this spyware cannot be removed. It keeps coming back after I delete extensions and reset settings and run all these programs in safe mode.
    I can't even find it in control panel -> uninstall programs. It's hiding!
  23. Run HiJackThis
    click on Scan
    after Scan click on Save log
    attach log file to you next replay
    I will try to see, what keep virus running
  24. Originally Posted by roma_turok View Post
    Run HiJackThis
    click on Scan
    Roma, here you go.
  25. Can you attach HOST file by
    In HiJackThis click on Main menu -> Open misc tools -> Open host file manager -> Open in Notepad
    save the file by Save as...
  26. This one? Doesn't seem to say anything.
  27. Originally Posted by lovingit View Post
    Yes its nothing right now
    but sometimes virus using HOST file to download
  28. What is on line 20?
    O20 - AppInit_DLLs: c:\progra~3\{a2af4~1\1173~1.1\siso.dll
  29. Originally Posted by roma_turok View Post
    What is on line 20?
    Hmm, I have no idea what that is. I tried a search for "AppInit" but nothing shows up.
