    Jun 2015
    UK
    I'm trying to capture video from a webcam. (The webcam works in other programs.)
    Capture device : /dev/video0
    Audio device : hw:1,0
    Video standard : PAL
    main error: open of `v4l2:///dev/video0' failed
    v4l2 error: cannot start streaming: Input/output error
    v4l2 error: not a radio tuner device
    Obviously no radio tuner should be involved.
    I tried blanking the radio device field in advanced options, but this did not work.
    Feb 2004
    Australia
    We see linux involved but without knowing the name of the application being used we can only guess as to why the error exists.
    And welcome to the forum ore
    Jun 2015
    UK
    Oh, sorry. I didn't realise the forum dealt with more than one application.
    This is vlc from the LinuxMint package 2.1.6-0ubuntu14.04.1
    Started from the GUI menu with:
    /usr/bin/vlc --started-from-file %U
    Other installed packages:
    vlc-data
    vlc-nox
    vlc-plugin-notify
    vlc-plugin-pulse
    Feb 2004
    Australia
    Try entering this into command line
    vlc v4l2:///dev/video0
    Linux EasyPeasy appears functional ... but with so much variance between linux distributions... things tend to break.
    Jun 2015
    UK
    $ vlc v4l2:///dev/video0
    VLC media player 2.1.6 Rincewind (revision 2.1.6-0-gea01d28)
    [0x1f44118] main libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
    "sni-qt/26365" WARN 07:41:02.943 void StatusNotifierItemFactory::connectToSnw() Invalid interface to SNW_SERVICE
    libv4l2: error turning on stream: Input/output error
    [0x7f7960000ec8] v4l2 demux error: cannot start streaming: Input/output error
    [0x7f7960000ec8] v4l2 demux error: not a radio tuner device
    [0x7f7960000e78] v4l2 access error: cannot start streaming: Input/output error
    [0x7f7978008db8] main input error: open of `v4l2:///dev/video0' failed
