I got a dvd sub and want to edit the timing and sync it with blu-ray sources?
The problem is the bluray video may add a few minutes so there will be a different frame rate!! i tried syncing it with Subtitle Edit but it didn't solve the whole timing issue, it syncs at first but then losses after a while! is there a way to fix this in vobsub or any other editor???? *There is only one non-english sub to this movie in subscene.
Either that or the Blu-Ray has some additional content. It should be an easy matter to determine the relative framerates. Have you checked?
And what kind of DVD subs do you have? VobSubs (IDX/SUB)? If so you can change the framerate (say, from 25 to 23.976 or 24fps) in SubtitleCreator, among other ways. -
The only way you can sync it to a blu-ray source with different timing is to manually adjust the time codes at the point where they change,if it's scene changes it will be a lot of work,if it's just a delay/advance then you can set the all the times codes ahead or back.
I use Subtitle Edit for my editing.I think,therefore i am a hamster. -
The problem is the bluray source is 4 minute more than the dvd one so it doesn't work with the simple way. If there is no way but point-sync that's difficult coz then i should change every line code.
It's not a subtitle editor so, no.
At the end there's a 4 minute difference between the voice and the subtitle? And is the film about 100 minutes (1 hour 40 minutes) long? If so you might be in luck. Your Blu-Ray is at film speed (23.976 or 24fps) while it sounds like your subs came from a PAL source. You can stretch the sub timings in SubtitleCreator, among other programs. I already mentioned this earlier yet you haven't even tried yet? Most subtitle programs have this ability since it's such a common problem. -
Stretch the sub as same as the video's frame rate?
Yes i found that SE has this feature. (Changing frame rates)
can you help me please with timing and milleseconds units?
By rama in forum EditingReplies: 14Last Post: 8th Nov 2014, 03:01 -
Doki Timing Guide - Creating / Timing Subtitles
By devilcoelhodog in forum SubtitleReplies: 0Last Post: 27th Jul 2013, 23:25 -
Audio timing?
By Timpe in forum Newbie / General discussionsReplies: 4Last Post: 3rd May 2013, 08:21 -
timing the subtitles
By sissou in forum SubtitleReplies: 8Last Post: 25th Jul 2012, 16:19 -
vsRip will not reset timing
By kenryuakuma in forum SubtitleReplies: 3Last Post: 26th Sep 2011, 17:45
