    Mar 2011
    Oregon, US
    I have a Sony Playstation 3 and a WDTV live. The videos are on USB Flash drive at 60 frames a second and no sound where on the WDTVLive box they play perfectly. Does the play station 3 have issues with USB Flash Drives? What can be one to rectify this problem?
    Thank you
  2. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Whats profile used? Whtas sound codec used? PS3 has some restriction about audio codecs on MP4 files.
    Post a mediainfo log here.
    Claudio
    Feb 2004
    Australia
    The following types of files can be played under Video:
    Memory Stick Video Format
    MPEG-4 SP (AAC LC)
    H.264/MPEG-4 AVC High Profile (AAC LC)
    MPEG-2 TS(H.264/MPEG-4 AVC, AAC LC)
    MP4 file format
    MPEG-1 (MPEG Audio Layer 2)
    MPEG-2 PS (MPEG2 Audio Layer 2, AAC LC, AC3(Dolby Digital), LPCM)
    MPEG-2 TS(MPEG2 Audio Layer 2, AC3(Dolby Digital), AAC LC)
    AVI
    Motion JPEG (Linear PCM)
    Motion JPEG (μ-Law)
    AVCHD (.m2ts / .mts)
    DivX
    WMV
    VC-1(WMA Standard V2)
    For the latest information, refer to the online user's guide at au.playstation.com/ps3/support/manuals.
    Note:
    Only files that are playable or viewable on the PS3 system are displayed in the column for the compatible category (Example: Image data is displayed under Photo).
    Depending on the storage media, only a subset of the folders on the media may be displayed. If you select [Display All] from the options menu, all folders saved on the media will be displayed.
    For files that do not show or playback use mediainfo to determine the video or audio codec and if not compatible either consider streaming or conversion
    canada
    You can install ums and play the files via DLNA with the sony ps3.
