Results 1 to 12 of 12
  1. I am trying to make a PAL DVD but the final result is showing interlacing scan lines when played on my DVD player. I have read other threads about people having the same problem when trying to encode a PAL dvd, but no solutions. This problem seems to exist when dealing with PAL specifically. Does anything in my script contradict with PAL in any way, maybe? (I have uploaded a short clip a couple of posts below.) Please help
    Source: 50p 1920x1080
    Avisynth script:
    AviSource("final2.avi")
    ConvertToYV12()
    Spline36Resize(720,576)
    Blur(0,0.5)
    ColorMatrix(mode="Rec.709->Rec.601",clamp=0)
    AssumeTFF().SeparateFields().SelectEvery(4, 0, 3).Weave()
    HCencoder:
    Bitrate - Avg 4000, Max 9000
    Profile - Best
    Aspect ration 16:9
    Autogop - 15
    Interlacing - auto detect, TFF
    Chroma Downsampling - progressive
    Matrix - manono3
  2. Interlacing - interlaced, TFF
  3. Originally Posted by jagabo View Post
    Tried that, exactly the same results unfortunately
  4. Upload a short sample of your M2V.
  5. Originally Posted by jagabo View Post
    here is a clip! Thank you
  6. That m2v is encoded progressive.
    Really! I'm using that avisynth script and those HCencoder settings, how can it be progressive? When I drop the clip into Premiere Pro it tells me it is 25.00i UFF? What am I doing wrong? Thank you!
  8. Go back and reencode as interlaced TFF again.
  9. Member Skiller's Avatar
    Oct 2013
    Germany
    Your sample is incorrectly flagged ("Frametype progressive" is true, which it should not) and also it was encoded using zig-zag scan type which is entirely incorrect for interlaced encoding.
    In HCenc, Settings 1:
    interlacing options (this determines the scan type and the "Frametype progressive" flag):
    • Interlaced
    • TFF
    Chroma downsampling shouldn't have any effect since you are feeding YV12 rather than YUY2.
    Interlacing options - Interlaced - TFF. Same thing!
  11. That one is properly encoded interlaced. It should play properly after authoring to DVD -- assuming you don't reencode it progressive.
    Amazing, it works! Thank you so much
