I have been lookin around for a good program to use for .avi to .mpeg conversion. I have tried vcdgalaxy(TMPGenc) with out any luck. Instead of converting my divx/.avi files it gives me an error for all of the movies that i have downloaded. I also tried avi2vcd but this program is extremely slow and can take up to a week or two to convert the file and it also gave me errors w/ frame converting. VCDEasy doesn't work and FlaskMpeg does not work either these only work to convert mpg to mpeg1 which is not the right file conversion for me. Please let me know about any good programs out there thank you.
Results 1 to 30 of 37
Get VirtualDub, open your DivX/AVI file, select Save WAV, then open TMPGEnc, open your AVI as the Video Input, and the WAV as the Audio Input and then load a VCD or SVCD Template, and encode.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
I used your method but I still recieve a "...can not open, or unsupported" error message from TMPGEnc when I try to load the original DivX/Avi file
. Thanks
Wow you should feel honored Sefy(He's the man) replied to your post .That last post of yours that wasn't back talk was it.I had the same problem as you. did you use the first guide under converting (divx to mpeg) like sefy basicaly told you too?Ok here is what to do go to the guide and there is a section near the bottom of it that says problems under that it says problems with tmpegenc press here, it will then tell you to change something a prioty 1 or 2 something of that nature can't really recall but that's what I did and wham! bam! bang! sorry I got all excited there and thought I was watching and old batman re-run. Oh by the way I'm not sure but I think Sefy wrote this guide(sorry to the auther if its not sefy no disrespect) . I know he has writen some of the other guides. If I can help anymore post it I 'll try to help
Thank you vcd4me, Ialthough i did not write any DivX=>VCD guide, I just wrote the DVD Backup guides, but i'm honoured that you think so highly of me.
camelmilk1, no need to get angry, you gotta do this logicly, first thing to consider, did you download both TMPGEnc and the TMPGEnc VFP Plugin ?
Secondly, did you register the TMPGEnc VFP plugin in the registry using the batch file which came with it ?
Did you put both TMPGEnc and the VFP in the same folder ?Email me for faster replies!
Best Regards,
Sefy Levy,
Sefy your more than welcome! I know you wrote some of the guides,and I surf this site alot and I always see your advice givien out to help the new as well as confused(like me). Anyways back to the subject for camelmilk1 I think that the new version of tmpegenc comes with the plugin of which you speak. I downloaded it just about two weeks ago and I followed the guide and had a problem and went to the problem section and read what to change in the vfp plugin and there it was just a few clicks latter and of course several hours of converting and a succesful burn then in front of the tv on my couch watching "the rookie" camelmilk just try again I have faith that you can do it. I got my computer in oct.2001 (never used one before) taught myself to do mp3s and moved on to vcds(got my high speed connection on march 18). Oh yeah and when I read the guide to converting divx/avi a few weeks ago I didn't even know what a zip file was but hey I asked everyone to help and they did!(thanks of you who have helped me) I'll help you man, isn't that what this site is for, helping each other sharing info and insite, I feel its kinda like the movie "pay it foreward"in a small way though. Hey if a computer ileterate clown like me can do it so can you!! Good luck and ask away! I'm listening!
Thanks for all your help. I'm trying to do what I can. Where can I get the newer version of TMPGEnc which comes with the VFP Plugin? I downloaded a program called VCD Galaxy which came with TMPGEnc but I'm pretty sure that it did not come with the VFP Plugin, I would really appreciate if I could get a direct link from someone to the download site. Oh and to answer your question vcd4me I did not mean any disrespect or back talk to Sefy, I was angry and frustrated because the program would not accept my DivX/Avi file. Thanks for all the help I really appreciate the fact that peopel take time out of their way to answer my questions and help me out. What's sad is that I'm a CE major but I don't really like the software aspect of it much I like the hardware part more :D .
camelmilk1, no harm done, I can understand when people get frustrated, it happens to everyone
As for your questions, here is a link for TMPGEnc Plus v2.53
http://www.pegasys-inc.com/e_download.html
And the VFP Plugin you can download from:
http://www.tmpgenc.net/e_download.htmlEmail me for faster replies!
Best Regards,
Sefy Levy,
Wow that was prompt a prompt reply
thanks for the links Sefy I'll dl the two and let you know how it goes tomorrow
I think I just emailed you the links too
Best Regards,
Sefy Levy,
Sefy,
That first link you gave me is TMPGEnc and the VFP plugin comes with it so the 2nd link was unnecessary although I'm going to dl the VFP Plugin just to be on the safe side thanks -
Yeah I just checked out my version. its 2.53. and that' ll I did was download that one version and it came with the plugin.Ok camelmilk1 just try it and post back and let us (myself and sefy) know how you made out. good luck-USE THE FORCE LUKE
install Divx 3.11a
http://www.divx-digest.com/software/divxcodec.html
TmpegEnc should no problem accept your avi
if not
install SMR patch
http://www.smr-movies.com/
then TmpegEnc should no problem accept your avi -
smr patch worked. it's working it's working
you guys are great thank you so much for all the help you've given me. any hardware advice or other problems w/ your gui i'm pretty fluent it most of it. email me for advice w/ that kinda stuff: camelmilk1@yahoo.com
thanks to all of you
now lets see if it can encode all the way without any errors and if i can burn it properly ha
thanks again -
Another question about TMPGEnc. Are you supposed to see a preview of the video as it is being encoded? also what's the average size of the mpeg converted video that comes out of the program?
To see the preview in TMPGEnc, make sure in the Option - Preview Option, it is set to "Display with thinning"
As for the size, if you are doing a standard VCD, each 1min of movie will take 10mb file size.Email me for faster replies!
Best Regards,
Sefy Levy,
error at 99%
aaaahhhhh damn thing. i input the video and it was accepted as both the video and audio source and then at 99% i got an error. so i redid it converted the movie audio to a .wav using virtual dub as sefy instructed. input the movie as video source and the newly converted .wav as the audio source. now we'll see how it works out and report back to you guys tomorrow
yo get the panasonic mpeg1 encoder. I think its better then TMPGEnc, or maybe its just my computer but when i encode wit TMPGEnc it comes out lookin choppy and blurry. But when i encoded wit panasonic it looked waaay better
where can i get the panasonic convertor ryu? can you post a link to it? thanks
No, i'm afraid he can't post a link, Panasonic Encoder is NOT a freeware, the maximum you can do is use the trial version.
There will be no links to illegal software on the forum for the sake of VCDhelpEmail me for faster replies!
Best Regards,
Sefy Levy,
still getting a black screen w/ audio only. does anyone have any solutions? i'm using the latest TMPGEnc
Thanks -
Since your source is an AVI, have you tried Frameserving from VirtualDub to TMPGEnc ?
Best Regards,
Sefy Levy,
Originally Posted by camelmilk1Visit the home of Fuzz
http://www.nobspangle.co.uk/ -
I just thought I had a Divx video I was encoding that gave an error near the end the error was not a fault with TMPGEnc but a fault with the actual .avi I can't remeber exactly but the error was something like "Invalid floating point Integer" I found that there was one corupt frame towards the end of the video. There might be a way to fix it as a work around I used the source range setiings and encoded all the frames before the offending one then all the frames after it then joined the two halves together.
Or you can use the VirtualDub to LSX example from my Complete Guide 2.0, and just use TMPGEnc instead of LSX: http://www.digital-digest.com/dvd/articles/dvdtovcd/frameserv3.html
Best Regards,
Sefy Levy,
alright i used the virtualdub frameserver to tmpgenc and recieved some interesting errors it didnt work properly and i don't know how to explain the errors they had something to do with ms visual c++ 6.0 which i have installed on my computer, i'm running win2k on my computer also if that might help solve anything. oh and where can i find the lsx mpeg encoder? is it in the tools section of this website?
There is some sort of problem with VirtualDub v1.4.10 when it comes to frameserving, I suggest you try getting a previous version like v1.4.9, that one works much better (you can check the VD frameserving topic).
Best Regards,
Sefy Levy,
alright i found the lsx mpeg encoder. i will try it out and let you know what happens sefy. thanks for the guide and the advice.
no audio during convertion of avi files
By blossom_suki in forum Video ConversionReplies: 7Last Post: 12th Apr 2010, 12:15 -
64-bit Video Convertion Program
By Trickynick in forum Video ConversionReplies: 15Last Post: 25th Feb 2010, 17:57 -
How to automate convertion from HD signal to HD-Divx or other format
By fta123 in forum DVB / IPTVReplies: 7Last Post: 18th Jan 2008, 11:55 -
DivX to DivX Convertion Problem
By Spiderm@n in forum Video ConversionReplies: 25Last Post: 4th Dec 2007, 05:15 -
What program gives the best quality results, when converting AVI/DIVX/XVID
By Rockstar452 in forum Authoring (DVD)Replies: 3Last Post: 3rd Dec 2007, 01:19
