I'm not sure where to post this, sorry. Here I go :
I want rtmpdump to automatically rip from crunchyroll. I've got rtmpdumphelper working right now. But, it's a pain to check website everytime for the release. How can I set it up to rip from crunchyroll automatically on a set time.?Any help would be great.
Thank You
Hi ,
You must create a task .
Look what is said at :
Cheers .Code:http://streameo.altervista.org/forum/viewtopic.php?f=6&t=1563
JE SUIS CHARLIE !!! -
Yes, you can use Windows' Task Scheduler to run any program at a set time, for a set duration. If you boot directly to Windows without a password you'll need to set up a password or another user account with a password. Task Scheduler requires an account with a password.
aazerty and jagabo.. thanx for reply... I already know this way.. this isn't a problem... the main problem is finding the URL of the stream... on crunchyroll... let's say.. I have to rip naruto shippuden.... I'd program the script to execute at certain time... But, I have to specidy the stream url, so, it can grab it.... how do I do that... that's the question...
Hi Scavvy ,
Well !
Your task must call a 'batch file' ( example below ) .
( or bash , php , etc. )
The major difficulty is on making the batch file working .Code:@echo on ".\livestreamer.exe" "hlsvariant://http://.../master.m3u8" best -o YourVideo.ts :fin
You have to do many tries .
Cheers .JE SUIS CHARLIE !!! -
To run a batch file from Task Scheduler you need to specify CMD.EXE as the program to run.
Code:C:\WINDOWS\system32\cmd.exe /c filename.bat
Is it possible to rip this video URL stream to a a file automatically?
By codecowboy in forum Video Streaming DownloadingReplies: 6Last Post: 23rd Apr 2015, 06:24 -
Can someone help? rtmpdump
By erhan_1498 in forum Video Streaming DownloadingReplies: 3Last Post: 23rd Oct 2014, 21:54 -
By erhan_1498 in forum Video Streaming DownloadingReplies: 10Last Post: 13th May 2014, 14:51 -
By RateD in forum Video Streaming DownloadingReplies: 3Last Post: 19th Aug 2012, 20:13 -
Using rtmpdump to schedule record and reconnect?
By RedPenguin in forum Video Streaming DownloadingReplies: 1Last Post: 4th Jul 2011, 23:04
