I've been searching all these threads for something I am certain was asked but can't find anywhere. I just want to know a program to combine my MKV files into one WITHOUT losing any quality. i don't have to shrink the files or anything because the quality is what's important to me. PLEASE can someone tell me how/what program to use... ? ::
Thanks in advance!!
	If your files match precisely as far as dimensions, codec, framerate, audio tracks etc, you can append one to the other in mkvtoolnix. Otherwise you're going to have to reencode one or the other and then combine. AviDemux or Handbrake are useful tools for that.
	The files so seem to match precisely. I used MakeMKV to rip part 1 and 2 of LoTR: Fellowship of the Rings extended editions (so I don't have to change the Blu-Ray to finish the movie)
 I have MKVtoolnix, but I don't see how to append the movies
	Hmm, the process I outlined earlier seems to combine them, but not append them in MKVToolnix. I normally use AviDemux to append files.
 In AviDemux, make sure to use the MKV muxer, video and audio on Copy and make a name for your new file with an .mkv extension.Last edited by Kerry56; 23rd Jun 2015 at 09:54.
	In the old GUI (mmg.exe) you add the first part (e.g. using drag&drop), then click "append" and select the second part. Then "mux". (Old GUI will be removed some time in future, so the exact process will change a bit)
	In the new mkvtoolnix-gui when you want to append a file you right click on the first file you added and choose append and add the file. I think,therefore i am a hamster.
	Worked like a charm. The quality is as if it were the blu-ray. Thank you all for the help. I truly appreciate it.
  Join or Combine 2 AVI files with no quality loss.By deadnuttz in forum EditingReplies: 18Last Post: 21st Sep 2016, 03:09
  MKVs - keep a good quality 1080p resolution but reduce the size?By StumpedTechy in forum Video ConversionReplies: 8Last Post: 9th Jan 2013, 08:46
  Which variables make best video quality in MKVs? bitrate/profile/ref framesBy dave in or in forum Video ConversionReplies: 9Last Post: 1st Mar 2012, 16:25
  Combine Mpeg-2 Files (without re-encoding or loss of quality)By Anonymous642 in forum Newbie / General discussionsReplies: 2Last Post: 26th Oct 2011, 07:58
  How to tell which has better quality? Curse Of the Golden Flower 1080p mkvsBy tigerb in forum Newbie / General discussionsReplies: 2Last Post: 6th Aug 2011, 23:28
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
