Results 1 to 9 of 9
  1. I seem to have a problem with all of my recorded HD files created with my Hauppauge.
    I record them using the 1212 and edit using VideoReDo.
    Then I use MultiAVCHD to author a disc. All files that are authored come out with a jump, both at the beginning and end of the file, almost as if the files themselves have lost a few frames.
    Now, the odd thing is that the files are still ok. If I wanted to re-encode all of them, i could and the problem would disappear so it's not as if something has been re-encoded or cut. It's a playback issue. However, I'd rather figure out what TSmuxer (by way of Multiavchd) is doing to the files. For some reason, whenever it gets a hold of them to change from ts to M2TS (or even just from .ts to .ts), they come out with this problem. Any suggestions?
    Jumpy on your computer or just standalone blu-ray/media player?
  3. Originally Posted by Baldrick View Post
    Both.
    Here's the mediainfo for both files.
    This is the original file BEFORE I sent it through tsmuxer:
    General
    Count : 308
    Count of stream of this kind : 1
    Kind of stream : General
    Stream identifier : 0
    Inform : MPEG-TS: 2.52 GiB, 25mn 13s
    Count of video streams : 1
    Count of audio streams : 1
    Video_Format_List : AVC
    Video_Format_WithHint_List : AVC
    Codecs Video : AVC
    Audio_Format_List : AC-3
    Audio_Format_WithHint_List : AC-3
    Audio codecs : AC3
    Audio_Language_List : English
    Complete name : D:\
    Folder name : D:\
    File name : Ellen Day 2 - 3.17.15
    File extension : ts
    Format : MPEG-TS
    Format : MPEG-TS
    Format/Extensions usually used : ts m2t m2s m2ts m4t m4s ts tp trp
    Commercial name : MPEG-TS
    Internet media type : video/MP2T
    Codec : MPEG-TS
    Codec : MPEG-TS
    Codec/Extensions usually used : ts m2t m2s m2ts m4t m4s ts tp trp
    File size : 2700887148
    File size : 2.52 GiB
    File size : 3 GiB
    File size : 2.5 GiB
    File size : 2.515 GiB
    Duration : 1513214.428333
    Duration : 25mn 13s
    Duration : 25mn 13s 214ms
    Duration : 25mn 13s
    Duration : 00:25:13.214
    Duration : 00:25:13;04
    Duration : 00:25:13.214 (00:25:13;04)
    Overall bit rate mode : VBR
    Overall bit rate : 14278928
    Overall bit rate : 14.3 Mbps
    Frame rate : 29.970
    Frame rate : 29.970 fps
    Frame count : 45348
    Delay : 10.156667
    Delay : 10ms
    Delay : 10ms
    Delay : 10ms
    Delay : 00:00:00.010
    Stream size : 134354009
    Stream size : 128 MiB (5%)
    Stream size : 128.1 MiB
    Proportion of this stream : 0.04974
    File creation date : UTC 2015-03-22 01:27:47.279
    File creation date (local) : 2015-03-21 21:27:47.279
    File last modification date : UTC 2015-03-22 01:28:33.681
    File last modification date (local) : 2015-03-21 21:28:33.681
    Video
    Count : 311
    Kind of stream : Video
    StreamOrder : 0-0
    Inform : 13.2 Mbps, 1920*1080 (16:9), at 29.970 fps, AVC (Main@L4) (CABAC / 4 Ref Frames)
    Menu ID : 1
    Menu ID : 1 (0x1)
    Format : AVC
    Format/Url : http://developers.videolan.org/x264.html
    Commercial name : AVC
    Format profile : Main@L4
    Format settings : CABAC / 4 Ref Frames
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4
    Format settings, ReFrames : 4 frames
    Internet media type : video/H264
    Codec ID : 27
    Codec : AVC
    Codec : AVC
    Codec/Family : AVC
    Codec/Info : Advanced Video Codec
    Codec/Url : http://developers.videolan.org/x264.html
    Codec profile : Main@L4
    Codec settings : CABAC / 4 Ref Frames
    Codec settings, CABAC : Yes
    Codec_Settings_RefFrames : 4
    Duration : 1513112
    Duration : 25mn 13s
    Duration : 25mn 13s 112ms
    Duration : 25mn 13s
    Duration : 00:25:13.112
    Duration : 00:25:13.112 (00:25:13;04)
    Bit rate mode : VBR
    Bit rate mode : Variable
    Bit rate : 13185549
    Bit rate : 13.2 Mbps
    Maximum bit rate : 19999744
    Maximum bit rate : 20.0 Mbps
    Width : 1920
    Width : 1 920 pixels
    Height : 1080
    Height : 1 080 pixels
    Pixel aspect ratio : 1.000
    Display aspect ratio : 1.778
    Display aspect ratio : 16:9
    Frame rate : 29.970
    Frame count : 45348
    Resolution : 8
    Resolution : 8 bits
    Colorimetry : 4:2:0
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : TFF
    Scan order : Top Field First
    Interlacement : TFF
    Interlacement : Top Field First
    Bits/(Pixel*Frame) : 0.212
    Delay : 200.000
    Delay : 200ms
    Delay : 200ms
    Delay : 200ms
    Delay : 00:00:00.200
    Delay, origin : Container
    Stream size : 2493903379
    Stream size : 2.32 GiB (92%)
    Stream size : 2 GiB
    Stream size : 2.3 GiB
    Stream size : 2.323 GiB
    Proportion of this stream : 0.92336
    Buffer size : 24999936
    Color range : Limited
    colour_description_present : Yes
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Audio
    Count : 285
    Kind of stream : Audio
    StreamOrder : 0-1
    Inform : English, 384 Kbps, 48.0 KHz, 6 channels, AC-3
    Menu ID : 1
    Menu ID : 1 (0x1)
    Format : AC-3
    Format/Info : Audio Coding 3
    Commercial name : AC-3
    Format settings, Endianness : Big
    Codec ID : 129
    Codec : AC3
    Codec : AC3
    Duration : 1513120
    Duration : 25mn 13s
    Duration : 25mn 13s 120ms
    Duration : 25mn 13s
    Duration : 00:25:13.120
    Bit rate mode : CBR
    Bit rate mode : Constant
    Bit rate : 384000
    Bit rate : 384 Kbps
    Channel(s) : 6
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Channel positions : 3/2/0.1
    ChannelLayout : L C R LFE Ls Rs
    Sampling rate : 48000
    Sampling rate : 48.0 KHz
    Samples count : 72629760
    Frame count : 47285
    Compression mode : Lossy
    Delay : 200.000
    Delay : 200ms
    Delay : 200ms
    Delay : 200ms
    Delay relative to video : 0
    Delay relative to video : 00:00:00.000
    Video0 delay : 0
    Video0 delay : 00:00:00.000
    Stream size : 72629760
    Stream size : 69.3 MiB (3%)
    Stream size : 69 MiB
    Stream size : 69.27 MiB
    Proportion of this stream : 0.02689
    Language : en
    Language : English
    Language : English
    Language : en
    Language : eng
    Language : en
    bsid : 6
    dialnorm : -24
    dialnorm/String : -24 dB
    compr : 0.53
    compr/String : 0.53 dB
    dynrng : 0.53
    dynrng/String : 0.53 dB
    acmod : 7
    lfeon : 1
    dialnorm_Average : -24
    dialnorm_Average/String : -24 dB
    dialnorm_Minimum : -24
    dialnorm_Minimum/String : -24 dB
    dialnorm_Maximum : -24
    dialnorm_Maximum/String : -24 dB
    dialnorm_Count : 284
    compr_Average : -0.25
    compr_Average/String : -0.25 dB
    compr_Minimum : -0.86
    compr_Minimum/String : -0.86 dB
    compr_Maximum : 1.94
    compr_Maximum/String : 1.94 dB
    compr_Count : 284
    dynrng_Average : -0.08
    dynrng_Average/String : -0.08 dB
    dynrng_Minimum : -0.71
    dynrng_Minimum/String : -0.71 dB
    dynrng_Maximum : 1.94
    dynrng_Maximum/String : 1.94 dB
    dynrng_Count : 284
    format_identifier : AC-3
    And then here's the file AFTER i send it through...
    General
    Count : 308
    Inform : MPEG-TS: 2.51 GiB, 25mn 13s
    Codecs Video : AVC
    Audio codecs : AC3
    Complete name : D:\
    Folder name : D:\
    File name : Ellen Day 2 - 3.17.15_new
    File extension : ts
    Format : MPEG-TS
    Format : MPEG-TS
    Codec : MPEG-TS
    Codec : MPEG-TS
    File size : 2700129884
    File size : 2.51 GiB
    File size : 3 GiB
    File size : 2.5 GiB
    Duration : 1513188.100000
    Duration : 25mn 13s
    Duration : 25mn 13s 188ms
    Duration : 25mn 13s
    Duration : 00:25:13.188
    Duration : 00:25:13;01
    Duration : 00:25:13.188 (00:25:13;01)
    Overall bit rate : 14275127
    Maximum Overall bit rate : 35500000
    Maximum Overall bit rate : 35.5 Mbps
    Frame rate : 29.970
    Frame count : 45345
    Stream size : 134445088
    Stream size : 128.2 MiB
    Proportion of this stream : 0.04979
    File creation date : UTC 2015-06-23 05:00:43.230
    File creation date (local) : 2015-06-23 01:00:43.230
    File last modification date : UTC 2015-06-23 05:01:04.169
    File last modification date (local) : 2015-06-23 01:01:04.169
    Video
    Count : 312
    StreamOrder : 0-0
    Menu ID : 1
    Menu ID : 1 (0x1)
    Format : AVC
    Codec ID : 27
    Codec : AVC
    Codec : AVC
    Codec/Family : AVC
    Duration : 1513011
    Duration : 25mn 13s
    Duration : 25mn 13s 11ms
    Duration : 25mn 13s
    Duration : 00:25:13.011
    Duration : 00:25:13.011 (00:25:13;01)
    Bit rate mode : VBR
    Bit rate : 13181936
    Maximum bit rate : 19200000
    Maximum bit rate : 19.2 Mbps
    Width : 1920
    Height : 1080
    Frame rate : 29.970
    Frame count : 45345
    Resolution : 8
    Resolution : 8 bits
    Colorimetry : 4:2:0
    Color space : YUV
    Bit depth : 8
    Bit depth : 8 bits
    Scan order : TFF
    Interlacement : TFF
    Delay : 4200000.000
    Delay : 1h 10mn
    Delay : 1h 10mn 0s 0ms
    Delay : 1h 10mn
    Delay : 01:10:00.000
    Stream size : 2493055036
    Stream size : 2 GiB
    Stream size : 2.322 GiB
    Proportion of this stream : 0.92331
    Buffer size : 24999936 / 24999936
    format_identifier : HDMV
    Audio
    Count : 285
    StreamOrder : 0-1
    Menu ID : 1
    Menu ID : 1 (0x1)
    Format : AC-3
    Codec ID : 129
    Codec : AC3
    Codec : AC3
    Duration : 1513120
    Duration : 25mn 13s
    Duration : 25mn 13s
    Bit rate mode : CBR
    Bit rate : 384000
    Bit rate : 384 Kbps
    Channel(s) : 6
    Frame count : 47285
    Delay : 4200000.000
    Delay : 1h 10mn
    Delay : 1h 10mn
    Video0 delay : 0
    Proportion of this stream : 0.02690
    Language : en
    Language : English
    Language : English
    Language : en
    Language : eng
    Language : en
    bsid : 6
    dialnorm : -24
    compr : 0.53
    dynrng : 0.53
    acmod : 7
    lfeon : 1
    dialnorm_Count : 1914
    compr_Average : -0.30
    compr_Average/String : -0.30 dB
    compr_Count : 1914
    dynrng_Average : -0.18
    dynrng_Average/String : -0.18 dB
    dynrng_Minimum : -0.86
    dynrng_Minimum/String : -0.86 dB
    dynrng_Count : 1914
    You could try author it with bdrebuilder. Disable all shrinking.
  5. Originally Posted by Baldrick View Post
    So you're saying that I should build it with MultiAVChd first and then use bdrebuilder? I would assume the problem would still be there because it would first have been through tsmuxer. It's not a problem with it within the authoring. I can just put it through tsmuxer from ts to ts and it's still there.
    Are there ANY lossless programs out there like multiavchd? Maybe I just drop it altogether? Or another lossless cutter besides videoredo? Either one of them clearly has to go But, either way, I'm screwed on the older recordings unless I go back and re-encode every single one of them.
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    I think bdrebuilder can import .ts/mpeg2 files directly.
  7. Originally Posted by Baldrick View Post
    Right but i assume it can't put together menus and what not. Some of my projects have 50+ files on them. I can't go without a menu for something like that.
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    Okey. Then I don't know what you can do.
  9. Originally Posted by Baldrick View Post
    Ouch. I just can't believe that, after all these years, multiavchd is still the ONLY authoring program that doesn't re-author...and it's not even updated anymore
