Hello friends..I'm trying to reauthor a bad disc and not having no luck. I'm using DGIndex and when i load the vob files and hit save project and demux video i get a message that says couldn't write d2v file is it read-only?
How can I get around this ?
no this is a burnt dvd that wasnt burnt correctly and only play on the computer and not in a dvd player. I want to reauthor it so it will play in a dvd player.
Oh.....OK.
I don't "do" DGIndex. If I need a simple, no menu DVD from another DVD I just use DVDShrink or DVDDecrypter.
Make sure its saving project and demuxing to a folder on C and not at the drive with the dvd in it ... thats its default option ... that be where the read only error shows.
The second may be caused by a user of a limited account, use administrator account removes a lot of read and write access problems.
M-DISC, Write Once and Read Forever?
By Nice2BHi in forum MediaReplies: 28Last Post: 16th May 2017, 14:02 -
WDTV Live needs to be physically disconnected when it couldn't play a file
By tigerb in forum Newbie / General discussionsReplies: 15Last Post: 29th Sep 2013, 14:50 -
Certain d2v file causing problems with MeGUI Avisynth Script Creator.
By Simcut in forum Newbie / General discussionsReplies: 5Last Post: 30th Jul 2012, 17:57 -
Sony Handycam DCR-HC42 can no longer read/write to tapes
By tgp1994@gmail.com in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 11th Jan 2011, 17:09 -
VirtualDub D2V file error
By Dr.Who in forum Video Streaming DownloadingReplies: 5Last Post: 17th Dec 2010, 15:23
