I'm new to video and I'm not sure were to post this question.
I'd like to be able to view mp4 and mp3 files (randomly/shuffling) from a usb drive on a TV which will be in my game room. Can anyone tell me if this is possible and how to go about it. I looked into purchasing a Samsung smart TV. The Samsung TV will do the shuffling of mp3's from the usb, but it seems like the TV won't do shuffling of mp4's. Is there a free App that might do shuffling of mp4's.
				Results 1 to 9 of 9
	Sounds like you are looking for some sort of 'jukebox' software (or streaming media server). How you implement this and cast to your tv is another problem.
 Here are a couple of examples (untested):
 http://www.wolosoft.com/en/juke/
 http://www.allmediaserver.org/features
 Good luck.
	I check out the 2 examples on your post, but that's not what I'm looking for.
 The easiest solution for me would be a Samsung Smart TV player app for mp4's that would do shuffle/random playing.
 Anyone have any suggestions.
	You can't add apps to a TV. All players and media players play video files in sequence. To play them out of order, you either browse and play one at a time, or create a playlist (PC playback only as far as I know). Google is your Friend
	Perhaps not helpful for the OP but ...PC playback only as far as I know
 A DVD player has a random function. Like
 https://www.youtube.com/watch?v=_joS0zaSaOo
	Gonna have to disagree with you there.
 See: http://www.samsung.com/uk/support/skp/faq/1052455 And many others...
	The easiest way is to connect a hdmi cable (probably from a laptop if you have 'hdmi out') and use any desktop app you like which has a shuffle play function.
  Viewing and editing HD TS filesBy Victor Delta in forum Newbie / General discussionsReplies: 3Last Post: 7th Sep 2014, 15:22
  Adding subtitles to an mp4 video for Apple TV 3 viewingBy lawllmaster in forum SubtitleReplies: 5Last Post: 13th Mar 2013, 09:40
  problem viewing avc filesBy maximov in forum Software PlayingReplies: 10Last Post: 11th Oct 2012, 10:36
  mp4 to mp3?By AshleyQuick in forum AudioReplies: 9Last Post: 20th Sep 2011, 11:42
  Creating MP3 audio files from MP4 videosBy Kiwi999 in forum Newbie / General discussionsReplies: 1Last Post: 2nd Aug 2011, 05:16
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
