What is wrong with BDtoAVCHD? It never works. I have two laptops and the same thing happens with both of my laptops. They are both running 64BIT as well. As soon as I start to analyse a blu-ray disc the software is not responding. The analyse session just goes on forever. One my other laptop the software start to run as normal for a minute and for no reason it says "not responding". I can't believe I'm going through so much bad luck with so much software just for the sake of one blu-ray movie. All I want to do is copy it to Region Free. The prices to buy the other ripping software is a rip-off because I'm not paying £40.00 for a piece of software that only lasts a year and it's not as if I'll use the software a lot.
Thanks.
BDtoAVCHD has no decryption capability. If you are using an original, commercially made disc as input it will not work.
There are options to buy lifetime versions of AnyDVD HD, DVDFab Blu-ray Copy and MakeMKV. In fact the only way to buy MakeMKV gives you the lifetime version, though it is free to use while in beta status.
AnyDVDHD lifetime is €119.
DVDFab Blu-ray Copy lifetime is $179 and incredibly overpriced. -
If none of that appeals to you, you can try the trials of the various lesser known, and far less reliable software from Ideal, Digiarty, Pavtube, and others of their kind. You might get lucky and find one of their trial versions that actually does what you want.
Not to mention that it doesn't seem to be penetrating that he needs a decrypter.
There are only a few decrypters worth a damn. Which he doesn't want to pay for.
Region coding should not an issue with a decrypted disc, as shown by fatbloke's screenshot in one of his other threads.
It should be removed by default. That doesn't seem to be penetrating either.
Maybe he's seen some spurious error message? But he never explained how he concluded he had a region code problem.
Pull! Bang! Darn!
BDtoAVCHD how to keep more than one subtitle
By frankarl in forum SubtitleReplies: 2Last Post: 19th Dec 2014, 09:24 -
I want help (BDtoAVCHD)
By posan in forum Video ConversionReplies: 3Last Post: 9th May 2014, 05:14 -
BDtoAVCHD made BD25 conversion too large for BD25 media
By AUTOBOT in forum Authoring (Blu-ray)Replies: 11Last Post: 20th Oct 2013, 18:03 -
BDtoAVCHD audio problem
By BILL9548 in forum Authoring (Blu-ray)Replies: 0Last Post: 14th May 2011, 14:55 -
bdtoavchd folder creation not working
By daj38 in forum Authoring (Blu-ray)Replies: 4Last Post: 5th Mar 2011, 07:18
