Hi, can anyone please suggest any simple way i can convert .MOD files to .WMV. I need to do this for a friend so he can play it back on his DVD player.
I don't need to be able to do anything fancy, editing etc to the video, just a simple conversion so his DVD player can play it.
I googled this but there just doesn't seem to be any straightforward answer. please help me if anyone can thanks.
Results 1 to 12 of 12
Anyway.
Try these.
1. Simply rename your .mod file to .mpg since that is all a .mod file basically is.
2. Try to load the .mod file into avidemux. I do not think that exports to .wmv (see the earlier response) but if it accepts it you should be able to copy the stream to a simple mpeg-2 file. (that dvd player will play that) -
Make/Model No ?
wmv is not necessarily .mov
And have you tried what I suggest ?. It helps to have feedback on the suggestions made. -
I dont know the make model. I havent yet tried what you suggested but I will in about an hour or two.
Literally all I wanted to know is how to convert .mod to .wmv that is all, I really didn't think it would be very difficult. -
And what kind of file is .MOD? I guess you don't mean the Commodore AMIGA Soundtracker Module format if you refer to video?
Well, Wikipedia knows something: Panasonic/JVC/Canon camcorder recordings. Looks similar to AVCHD structures, so the MOD files are probably in fact M2TS.
So I would recommend too. Author it as regular DVD-Video.Originally Posted by Wikipedia -
I will try whats suggested soon, but I cannot author it on dvd because my friend play his files off of a portable HDD which stores all his videos on. His .mod files won't play but the .wmv and .mp4 files will from the HDD via a DVD player/TV.
i tried FFQueue I select add, then try to add one of the .MOD files in input #1 but I get this strange message. Then I try to save the job, and it I must select atleast one stream before saving a job. I have no idea what any of this means.
Is it really this difficult to convert .mod to .wmv in 2015 ? lol -
What strange message? FFQueue will probe the .MOV (or .MOD?) using FFprobe (part of FFmpeg bundle) and it would be nice to know if there are any problems with this? FFQueue will not allow you to save a job that has no streams (or no content) to process because this would make no sense
Can you try to run the command:
And post what comes out? You can append ">ffprobe_output.txt" to the command above to get it stored in a text file..Code:C:\Path\To\FFmpeg\bin\ffprobe.exe -pretty -show_format -show_streams "D:\path\to\your\video.mov"
P.S: If the video has the extension *.MOD - please try to rename it to *.MPG and try reencoding it with FFQueue again. It might be because FFprobe does not recognize MOD as actually being MPG.I'm the developer behind FFQueue. My posts might reflect this! ;-) -
Again, you are not reading what is being written. Allow me to attempt to clarify.
Mov is a container format. Back in the time of the ark it meant apple quicktime as the underlying video codec. I hardly expect any dvd player accepting that which requires a PC installed codec to run.
Today, container formats are more advanced. So....
...that .wmv file that your friend's player accepts more than likely is mpeg2 inside that container.
You have been asked more than once to attempt to simply rename that .MOD file to .mpg. Have you tried ?. Did it not work ?
And, yes, if you get errors in trying the methods suggested you have to report them ad-verbatim. No one here is a mind-reader.
But, also, .mp4 is another container format. Just because the file is an mp4 there is no guarantee that it will play and more so if you were to chose the wrong codec.
Make this a little easier for all of us. Get the make/model of this dvd player from your friend.Last edited by DB83; 30th Jun 2015 at 04:59. Reason: typo clarity
Cannot convert wmv
By correx in forum Video ConversionReplies: 48Last Post: 16th Dec 2014, 19:23 -
[SOLVED] Convert MOD video using ffmpeg for use with VirtualDub?
By yetanotherlogin in forum EditingReplies: 9Last Post: 13th May 2012, 20:25 -
trying to email MOD video clip, too big. How do I convert??
By Crunchberry in forum Video ConversionReplies: 8Last Post: 22nd Mar 2012, 23:55 -
Best way to convert MOD to DVD?
By erzielin in forum Authoring (DVD)Replies: 3Last Post: 2nd Jan 2012, 10:16 -
Convert .mod to .mov
By ipaddle4fun in forum Video ConversionReplies: 1Last Post: 6th Mar 2011, 16:41
