I'm new to video editing and I don't even know which video or audio codecs to choose for creating a DVD. I'm using Open Shot in my Linux Mint 17 . Could some one please fill me in on this simple question. I've looked all over the place and don't find a direct answer. . I've tried with mpeg2 and ac3 so far but every time I export it gets to the end and says it's completed but then Open Shot hangs and I have to force close the exporter . If it even created a file there is nothing there. I'm not sure the path to Blender is right and I've seen documentation that makes me think this might be a problem also ; but I'm not good enough yet with Linux to fix it . Any suggestions would be very welcome. thank you
I'm also running Linux Mint 17.1 on a couple of PC's. To be honest, I never tried to Author a dvd in Linux, in fact it's been years since I've Authored any dvd's at all for that matter. all dvd's require Mpeg-2 video and ac3 (NTSC) audio for compliance. It's best to set GOP at 15 for 29.97 fps and 12 for 23.976 fps.
Sorry that I can't help any more than that, but dvd's are ancient history for me and I really don't care much about them anymore.Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
Thank you for your helpful replies; now I at least know I have some things right
AC3 is the most common type of audio on DVDs, even if it is not the only choice available. The DVD spec requires one audio track to be AC-3 or PCM for NTSC DVDs. MPEG-1 Layer II audio is also allowed by the DVD spec, although not as the only audio track for NTSC DVDs, but some DVD players and authoring software don't care if it is the only audio track provided.
Yes , thank you all. Please keep replying with these pieces of info .
I have DVDStyler too . I think Open Shot is user friendliest/easiest for me to navigate and figure out. Now that you mention it I'm gonna go back and check out Styler again.
I think I'll have to go to the Blender and Open Shot forums too. Since I had the codecs right I don't know why it fails. More research.
Convert video to dvd format without K-Lite Mega Codecs??
By tfamok in forum Newbie / General discussionsReplies: 4Last Post: 2nd Oct 2014, 10:58 -
lossless codecs for ripped DVD-Video?
By shun in forum Video ConversionReplies: 4Last Post: 7th Jul 2014, 18:45 -
codecs for Womble MPEG Video Wizard DVD
By hoankiem0950 in forum EditingReplies: 14Last Post: 14th Feb 2014, 20:07 -
Multiple questions on DVD Ripping / Format / Codecs
By mediafan26 in forum DVD RippingReplies: 5Last Post: 14th Apr 2012, 18:17 -
Having issues with dvd ripping and codecs - cant tell whats installed
By alex.ap.pacman in forum Newbie / General discussionsReplies: 2Last Post: 15th Sep 2011, 01:40
