I would like to use a 24 bits color picture as part of a subtitle stream in a mkv that would be played correctly at least in Windows with DS player (MPC-HC) and VLC. It would be great that worked in Android too (with MX Player).
I think there are two kinds of subtitles that would suit me: ASS and USF. Although USF seems the answer, also nobody uses them. No editor but, well, I think I could write a test by hand to see the possibilities.
I got to this webpage, with that enigmatic sentence:
http://www.matroska.org/technical/specs/subtitles/index.html
Close to that, this one:Because a "subtitle" stream is actually just an overlay stream, anything with a transparency layer could be use, including video.
http://www.matroska.org/technical/specs/subtitles/ssa.html
And the "full" specifications of ASS subtitles (http://moodub.free.fr/video/ass-specs.doc) states that you can write in addition to Dialogue events, Picture and Movie events. Pictures can be uuencoded (that I would prefer to avoid) or as an external file (maybe embedded in mkv just as you do with a needed font in this format?).Wav: 0, 128697,D:\Alex\Anime\- Fansub -\- TAFF -\Wolf's Rain\WR_-_02_Wav.wav
Wav: 0, 120692,H:\team truc\WR_-_02.wav
Wav: 0, 116504,E:\sub\wolf's_rain\WOLF'S RAIN 02.wav
LastWav: 3
I've tried following the instructions to no avail to make appear a movie or picture (png) with an ASS subtitle.
Also, I have seen ASS scripts made with Aegisub that use pictures as part of a karaoke effect. Although they work inside Aegisub, the effects aren't seen in MPC-HC with VSFilterMod. I think fansubbers use this scripts to hardsub, which is not what I want. I want to add a subtitle track that you are able to turn on and off.
In short, is there a way to add a color picture as part of subtitles? Could anyone make a "Hello world I am a picture in a subtitle" sample that work with any combination of OS/player/filter(s)/sub format?
TIA
Results 1 to 1 of 1
Show Your Best Halloween Picture
By budwzr in forum Off topicReplies: 0Last Post: 1st Nov 2013, 22:47 -
Potplayer. Make both upper and lower part of skin show up simultaneously?
By hemstock in forum Software PlayingReplies: 0Last Post: 15th Sep 2013, 10:35 -
Is It Possible To Create A Custom Color From A Picture, For Text In Paint?
By V Bot in forum ComputerReplies: 10Last Post: 1st May 2011, 22:00 -
Rip a part from a dvd with subtitles
By itoo73 in forum Newbie / General discussionsReplies: 5Last Post: 13th Feb 2011, 14:20 -
Question about valuable part in neck of picture tube
By jimdagys in forum Newbie / General discussionsReplies: 15Last Post: 1st Dec 2010, 07:11
