  1. I'm having problems downloading video files from a site.
    For example, when I put this address into the Convert/Save:
    http://hlsioscwtv.warnerbros.com/hls/2014/11/21/WBITV_Marketing_WHOSE_LINE_IS_IT_ANYWA..._2100kbps.m3u8
    it always stops partway through. It doesn't stop at the same place every time but it never makes it all the way through. I've tried "dumping the raw input" and re-encoding and I get the same problem with both of them. I've also tried different sites with similar types of files with the same results.
    Can anyone help? It doesn't show an error. It just...stops.
  2. It must be something local to you. I was able to download the complete video twice with VLC. Once muxed into MP4 and the second time muxed into TS. I used version 2.0.7.
  3. Originally Posted by jagabo View Post
    Crap. Any idea what to check?
